heim joints/rod ends ? #1043704
07/31/11 09:10 AM
07/31/11 09:10 AM
moparx Offline OP
moparx  Offline OP
how 'bout a discussion on heim joints or rod ends. such as uses for "standard" vs lined[nylon/kevlar race] vs cromoly. also include thoughts on those "seals" available - the rubber disc cover bonded to a thin washer. as always, thanks in advance !
Re: heim joints/rod ends ? [Re: moparx] #1043705
07/31/11 10:08 AM
07/31/11 10:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I usually buy the moly ones... yes they are pricey but
I dont want them to break... I had some cheap ones break
on my steering.... also make sure you use the high
angular heims on the steering... I havent tried the
dust covers yet but I do have some for my currant build
Re: heim joints/rod ends ? [Re: MR_P_BODY] #1043706
07/31/11 10:22 AM
07/31/11 10:22 AM
ill
dennismopar73 Offline
ill
mr p,, what high angular hiem ?? reason for asking i need to channge up my steering from the stock rod ends to a hiem, and also what recomends do you have as for as a spacer, metal / aluminum??
Re: heim joints/rod ends ? [Re: dennismopar73] #1043707
07/31/11 10:34 AM
07/31/11 10:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
High angular heims give you more movement so the tie
rods wont go into bind... a standard usually WILL go
into bind at full travel... thats the reason mine
broke... the high angular will give you about 12* to
18* more angle (dependent on size)... as for the spacer
alum is fine if you have enough diameter so it cant
pivot
Re: heim joints/rod ends ? [Re: MR_P_BODY] #1043708
07/31/11 10:42 AM
07/31/11 10:42 AM
MD
ADakotaRTGuy Offline
MD
Where do you find the high angular ones?
Re: heim joints/rod ends ? [Re: MR_P_BODY] #1043709
07/31/11 10:47 AM
07/31/11 10:47 AM
ill
ill
i thought thats what it was ,, wasnt for sure,
thanks,
when we done my front end , it front steer now but the issue is that
when tires come off ground the rod ends these are stock ends, are touching the strut bars
,not good, so a fellow racer said in order to get up away from it
to raise the ends and put hiem on it still worried about the arch travel, i have the book that tells me about that issue , but rather confusing as to the fix , ?
Re: heim joints/rod ends ? [Re: ADakotaRTGuy] #1043710
07/31/11 10:58 AM
07/31/11 10:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I get them through Summit but they dont show them...
I give Summit the P/N and they have them drop shipped
to the house(this company doesnt deal direct)
Also they have a inset thing to change the standard
heim to a high angle..... they are acually called
high misalignment
http://www.fkrodends.com/HRSMXTHINT25.html
Re: heim joints/rod ends ? [Re: MR_P_BODY] #1043711
07/31/11 11:02 AM
07/31/11 11:02 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Aurora chrome moly is the only rod end that I will use.
Leon
Re: heim joints/rod ends ? [Re: Leon441] #1043712
07/31/11 11:18 AM
07/31/11 11:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Leon
I use Aurora most of the time also
Re: heim joints/rod ends ? [Re: MR_P_BODY] #1043713
07/31/11 11:25 AM
07/31/11 11:25 AM
Dyno1 Offline
Dyno1  Offline
QA1 has a large selection of whatever you need. Ask for Dave or Jeff.
Re: heim joints/rod ends ? [Re: Dyno1] #1043714
08/01/11 10:10 PM
08/01/11 10:10 PM
moparx Offline OP
moparx  Offline OP
moly is always the best for suspension parts in my opinion due to the stresses involved. but what about other uses, such as push-pull motions in brake pedal rods, throttle linkage, battery cutoff switches, etc. also, is the general consensus more to a "lined" race[nylon/kevlar material] than non-lined[metal-to-metal] race?
Re: heim joints/rod ends ? [Re: moparx] #1043715
08/02/11 12:11 AM
08/02/11 12:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The smaller stuff you dont need the big dollar stuff
like throttle... I dont even use a heim on the brake
pedal... tie rods you want good ones... if its a
chassis point(ladder bars/4-links I use the moly
no liner...I dont want that getting beat out and
having a loose/worn out heim... I clean and lube
them but you can try the dust covers
Re: heim joints/rod ends ? [Re: MR_P_BODY] #1043716
08/02/11 12:43 AM
08/02/11 12:43 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Chrome moly, teflon lined FK rod ends period!
Re: heim joints/rod ends ? [Re: Al_Alguire] #1043717
08/02/11 03:14 AM
08/02/11 03:14 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
http://www.rodendsupply.com/index.php
These guys seemed pretty fair on price
Alan Jones
Re: heim joints/rod ends ? [Re: LA360] #1043718
08/02/11 04:55 AM
08/02/11 04:55 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Ruff Stuff Off Road has some of the best prices on Heims that I have seen...
I am truckless..
Re: heim joints/rod ends ? [Re: 340SHORTY] #1043719
08/02/11 06:24 AM
08/02/11 06:24 AM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Aurora XAM and XAB is a quality product, as many other out there
Re: heim joints/rod ends ? [Re: RT540] #1043720
08/02/11 10:57 AM
08/02/11 10:57 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Chassisshops.com
Re: heim joints/rod ends ? [Re: theclutcher] #1043721
08/02/11 03:01 PM
08/02/11 03:01 PM
MD
MD
What do you guys think of these?
http://www.summitracing.com/parts/SUM-MAXL10T/
Re: heim joints/rod ends ? [Re: ADakotaRTGuy] #1043722
08/02/11 10:04 PM
08/02/11 10:04 PM
moparx Offline OP
moparx  Offline OP
here is the setup i fabbed for my humpback. master is behind dash @ 90*. i just used the "economy" rod ends. strong enough for this application ?
Re: heim joints/rod ends ? [Re: moparx] #1043723
08/02/11 10:29 PM
08/02/11 10:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Should work fine
Ive use those before on a customers car(he suppied)
for a 4 link... they lasted pretty good
