Re: heim joints/rod ends ?
[Re: moparx]
#1043705
07/31/11 10:08 AM
07/31/11 10:08 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I usually buy the moly ones... yes they are pricey but I dont want them to break... I had some cheap ones break on my steering.... also make sure you use the high angular heims on the steering... I havent tried the dust covers yet but I do have some for my currant build
[Re: dennismopar73]
#1043707
07/31/11 10:34 AM
07/31/11 10:34 AM
MR_P_BODY
mr p,, what high angular hiem ?? reason for asking i need to channge up my steering from the stock rod ends to a hiem, and also what recomends do you have as for as a spacer, metal / aluminum??
High angular heims give you more movement so the tie rods wont go into bind... a standard usually WILL go into bind at full travel... thats the reason mine broke... the high angular will give you about 12* to 18* more angle (dependent on size)... as for the spacer alum is fine if you have enough diameter so it cant pivot
[Re: MR_P_BODY]
#1043709
07/31/11 10:47 AM
07/31/11 10:47 AM
Posts: 2,177 ill
dennismopar73
ill
i thought thats what it was ,, wasnt for sure, thanks, when we done my front end , it front steer now but the issue is that when tires come off ground the rod ends these are stock ends, are touching the strut bars ,not good, so a fellow racer said in order to get up away from it to raise the ends and put hiem on it still worried about the arch travel, i have the book that tells me about that issue , but rather confusing as to the fix , ?
[Re: ADakotaRTGuy]
#1043710
07/31/11 10:58 AM
07/31/11 10:58 AM
MR_P_BODY
Where do you find the high angular ones?
I get them through Summit but they dont show them... I give Summit the P/N and they have them drop shipped to the house(this company doesnt deal direct) Also they have a inset thing to change the standard heim to a high angle..... they are acually called high misalignment http://www.fkrodends.com/HRSMXTHINT25.html
[Re: MR_P_BODY]
#1043711
07/31/11 11:02 AM
07/31/11 11:02 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Aurora chrome moly is the only rod end that I will use.
Leon
[Re: Leon441]
#1043712
07/31/11 11:18 AM
07/31/11 11:18 AM
MR_P_BODY
Leon
I use Aurora most of the time also
[Re: moparx]
#1043715
08/02/11 12:11 AM
08/02/11 12:11 AM
MR_P_BODY
moly is always the best for suspension parts in my opinion due to the stresses involved. but what about other uses, such as push-pull motions in brake pedal rods, throttle linkage, battery cutoff switches, etc. also, is the general consensus more to a "lined" race[nylon/kevlar material] than non-lined[metal-to-metal] race?
The smaller stuff you dont need the big dollar stuff like throttle... I dont even use a heim on the brake pedal... tie rods you want good ones... if its a chassis point(ladder bars/4-links I use the moly no liner...I dont want that getting beat out and having a loose/worn out heim... I clean and lube them but you can try the dust covers
[Re: LA360]
#1043718
08/02/11 04:55 AM
08/02/11 04:55 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Ruff Stuff Off Road has some of the best prices on Heims that I have seen...
I am truckless..
[Re: RT540]
#1043720
08/02/11 10:57 AM
08/02/11 10:57 AM
Posts: 2,172 Ohio
theclutcher
Ohio
[Re: moparx]
#1043723
08/02/11 10:29 PM
08/02/11 10:29 PM
MR_P_BODY
here is the setup i fabbed for my humpback. master is behind dash @ 90*. i just used the "economy" rod ends. strong enough for this application ?
Should work fine
--------------------------------- What do you guys think of these?
Ive use those before on a customers car(he suppied) for a 4 link... they lasted pretty good
