Page 2 of 3 1 2 3
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: Dragula] #1043530
07/31/11 12:48 PM
07/31/11 12:48 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
647 hp, I'll be (pleasently) suprised if you have enough head on it for more, even with the big cam. With those cubes and still smallish ports the torque will be legendary...the kind Vikings write poems about
My question is, why only the 2.02" on such a big cube motor?
Also from my experience the econo's don't seem to rev as high as the billet pedestal W2's when you're dealing with high RPM roller spring pressures.
WIZE
In Car:
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: Streetwize] #1043531
07/31/11 01:07 PM
07/31/11 01:07 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
devilish 666 hp will be my low gues,that thing should make some brutal torque in the midrange the more i look into W2 motors the more impressive they are
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: Streetwize] #1043532
07/31/11 11:31 PM
07/31/11 11:31 PM
Alberta Canada
StrokerAspen Offline OP
Alberta Canada
Although, this isn't really a "budget build" In a way it still is. The W2's with 2.02" was the top end I have, and if I want to race this year, that's all the budget allows for.
Ideally, If money was no object, and time wasn't my enemy, you would see a set of CFE W8's on this thing! But, again, this makes for a differnt build still, and kind of an out of the ordinary build. My Aspen still has an 8 3/4 with stock everything in it, so, the car isn't really ready for a whole ton of power anyway.
-Kenny
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: StrokerAspen] #1043533
07/31/11 11:44 PM
07/31/11 11:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
-Kenny
I'm with Wise and a few others... that thing will
make a TON of torque(watch out for your 8 3/4) but
the cross section of the port isnt anywhere near enough...
so with all that torque I sure hope you dont have
steep gears
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: MR_P_BODY] #1043534
07/31/11 11:51 PM
07/31/11 11:51 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i'd say mid 600's hp...
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: MR_P_BODY] #1043535
08/01/11 12:28 AM
08/01/11 12:28 AM
Alberta Canada
Alberta Canada
-Kenny
steep gears
3.23's set up with hopes and dreams of it hanging together!
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: StrokerAspen] #1043536
08/01/11 12:33 AM
08/01/11 12:33 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
673.333333333
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: Stroker Scamp] #1043537
08/01/11 12:43 AM
08/01/11 12:43 AM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Is it going into your Aspen???
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: MIKES_DUSTER] #1043538
08/01/11 12:58 AM
08/01/11 12:58 AM
Alberta Canada
Alberta Canada
It will be until the other car is ready for an engine. The other car is a 1967 Plymouth Valiant that I just bought. That car will have a Jerico DR4 and a Dana 60.
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: Stroker Scamp] #1043539
08/01/11 01:16 AM
08/01/11 01:16 AM
Alberta Canada
Alberta Canada
That specific eh? remember, we are using a manual operated Stuska brake. Haha. That means, we read the number off of the dial and at what RPM it comes off at, then we calculated the power by hand. So, it wont be that specific.
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: StrokerAspen] #1043540
08/01/11 02:34 AM
08/01/11 02:34 AM
pacific northwest
pacific northwest
ok take about 3-3's off that and add a 4
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: Stroker Scamp] #1043541
08/01/11 06:48 AM
08/01/11 06:48 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
620 hp.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: DusterDave] #1043542
08/01/11 10:44 AM
08/01/11 10:44 AM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
631.8 hp
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: BradD] #1043543
08/01/11 12:08 PM
08/01/11 12:08 PM
sweden
sshemi Offline
sshemi  Offline
sweden
680hp
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: sshemi] #1043544
08/01/11 01:09 PM
08/01/11 01:09 PM
Outside
thedriver Offline
thedriver  Offline
Outside
8 billion hp
1973 challenger
Dana. 4 speed. Low deck.
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: thedriver] #1043545
08/01/11 02:56 PM
08/01/11 02:56 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
8 billion hp
He would probably break the speed of light with that much power!
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: Big B] #1043546
08/01/11 03:02 PM
08/01/11 03:02 PM
People's Republic of Mass.
Belvedere2 Offline
Belvedere2  Offline
I'll tell ya if it goes into my car.
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: Belvedere2] #1043547
08/01/11 04:29 PM
08/01/11 04:29 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Well?
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: StrokerAspen] #1043548
08/01/11 04:30 PM
08/01/11 04:30 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
So when is it going on the dyno?
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: Big B] #1043549
08/01/11 11:17 PM
08/01/11 11:17 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
8 billion hp
Only if he can get traction...
Page 2 of 3 1 2 3
