Ideas on speedometer bouncing/noise #1043488
07/30/11 09:42 PM
07/30/11 09:42 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
904 '73 Duster, has a new cable in it. I thought I greased it, not sure. it bounces around, holds steady at the wrong but close speed and then bounces around, if you listen you'll hear a tingy or ringing sound from it..What could that be?
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: Ideas on speedometer bouncing/noise [Re: MonGoo$e] #1043489
07/30/11 11:21 PM
07/30/11 11:21 PM
dart1962_440 Offline
My speedo did this on my GTX and it turned out that the speedo cable wasn't fully installed on the back of the speedometer.
Re: Ideas on speedometer bouncing/noise [Re: dart1962_440] #1043490
08/01/11 03:41 AM
08/01/11 03:41 AM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
I had my barracuda speedo rebuilt at a local speedo shop because of the same issue. They said that bushings inside let the rotating parts wobble and come into contact with each other and make that tingy noise. It was smooth as butter after the rebuild. I actually had one speedo that broke the needle off because of the bouncing.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: Ideas on speedometer bouncing/noise [Re: phantomx] #1043491
08/01/11 03:58 AM
08/01/11 03:58 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
It pays to look at all the parts to the puzzle. The speedometer itself can be failing. The cable at the speedo could be loose. The lube in the cable may have dried out. The rotating cable inside may have frayed. The cable screw cap at the trans could be loose or on crooked. The speedo pinion may be out of adjustment. Finally, the pinion may have one or more teeth chipped.
Re: Ideas on speedometer bouncing/noise [Re: Kern Dog] #1043492
08/01/11 02:18 PM
08/01/11 02:18 PM
Maryland
brianz426 Offline
brianz426  Offline
Maryland
I agree with all of the Frankenduster. My Cuda speedometer was bouncing, turned out the cable was dried out. I cleaned and lubed it, it's been fine since.
Re: Ideas on speedometer bouncing/noise [Re: brianz426] #1043493
08/01/11 04:26 PM
08/01/11 04:26 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
lub the cable
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Ideas on speedometer bouncing/noise [Re: phantomx] #1043494
08/01/11 08:11 PM
08/01/11 08:11 PM
BDW Offline
BDW  Offline
Travis..
Exact same experience here, actually broke 2 needles before getting the right diagnosis.
Re: Ideas on speedometer bouncing/noise [Re: MonGoo$e] #1043495
08/01/11 09:15 PM
08/01/11 09:15 PM
Kirkland, Washington
Pacnorthcuda Offline
Also make sure you have no sharp bends in the cable--especially behind the speedo itself. The cables operate a LOT smoother when they are straight as possible. On some cars thats not easy
Re: Ideas on speedometer bouncing/noise [Re: Pacnorthcuda] #1043496
08/01/11 10:23 PM
08/01/11 10:23 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
The tingy sound is the key. That usually means the bushings in the speedo are worn and the rotating parts are touching. Squealing can be the cable.
