exhaust manifolds, no paint..resto.. #1043422
07/30/11 09:04 PM
07/30/11 09:04 PM
MO
cdp Offline OP
cdp  Offline OP
MO
What is the process to restore my exhaust manifolds without painting?
Sandblast and gear oil, with a little overspray when the engine is painted?
Re: exhaust manifolds, no paint..resto.. [Re: cdp] #1043423
07/30/11 09:52 PM
07/30/11 09:52 PM
I would think the engine paint would not stick to the manifolds with the gear oil on it.
Re: exhaust manifolds, no paint..resto.. [Re: ] #1043424
07/30/11 10:12 PM
07/30/11 10:12 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
All engines were assembled with the manifolds on them,then painted.
As we all know,the paint on the manifolds lasted not long after being driven.
So,the "correct" look is..paint burned off and bare metal.
For those who prefer opening the hood like a jewelery box,using POR-15,or Eastwood's manifold paint is better looking than rusty exhaust manifolds.
Many of us have done tons of detailing under the hood and the products mentioned above have become acceptable in the hobby
In the past,I gave my logs a good blast of glass beading for the "au-natural look,LOL!As time went by they showed there true age.
This time I am using the POR-15.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: exhaust manifolds, no paint..resto.. [Re: 68Cbarge] #1043425
07/30/11 10:23 PM
07/30/11 10:23 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The oil process you mentioned works. I think another new product on the market deserves a chance as well, ECS "RPM" product. Clean the metal spotless of rust via blasting, etc. Give it a good coating of the RPM, heat and let it flow as directed. When cool and dry (doesn't take long) add them to the engine and paint as usual. Most of the paint will burn off pretty fast but some will usually remain around the ports and bolts, etc. The RPM is a heat activated product and it may or may not work on something that gets so hot, but I think it's a good canidate to try and see what happens.
Re: exhaust manifolds, no paint..resto.. [Re: ScottSmith_Harms] #1043426
07/30/11 10:33 PM
07/30/11 10:33 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I also wondered if paint would stick to a manifold that was dipped in gear oil. My guess is that it probably would stick since you burn off the excess with a torch first. Maybe I'll get to that stage this winter...I said that last summer too.
The few parts I've used RPM on, seem slightly waxy after they have cooled off. I don't think the paint is going to work. Maybe the RPM could be applied after the mounting flanges have been painted? I guess both ways are worth a try.
Re: exhaust manifolds, no paint..resto.. [Re: burdar] #1043427
07/30/11 10:54 PM
07/30/11 10:54 PM
If you put the paint on and then the RPM, you are kinda defeating the purpose of putting the RPM on since the painted area will burn off and then rust leaving the other are with the RPM nice and clean. Also, I wonder how well the RPM will hold up to the extreme heat? My guess is that with the constant heat, it will thin out like when you apply the stuff on a heated part and then run off causing a mess. If it doesn't then I know what I am doing next winter!
Re: exhaust manifolds, no paint..resto.. [Re: burdar] #1043428
07/30/11 10:57 PM
07/30/11 10:57 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Never tried it myself but I have heard of rubbing them with graphite after blasting. Supposedly they don't rust and still retain the cast look.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: exhaust manifolds, no paint..resto.. [Re: 5wndwcpe] #1043429
07/30/11 11:18 PM
07/30/11 11:18 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Well....I went with the gear oil route. We'll see what happens. Won't get fired back up for a week, but I'm expecting a little bit-O-Smoke from the process. Here is a pic of the mock-up.
Re: exhaust manifolds, no paint..resto.. [Re: 5wndwcpe] #1043430
07/30/11 11:27 PM
07/30/11 11:27 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
If you clean and paint the inside of the manifolds with ceramic header coating it should help slow down, or even prevent, the paint from burning off.
My brother plays around with oldsmobiles and like all the B.O.P. family of engines the exhaust ports are cast outside the main cylinder head architecture which pretty much guarantees the engine paint will burn off before the engine is even broken in. He just freshened up a 350 olds a few weeks back and before he put the heads back together he applied header coating all the way up inside the exhaust ports. So far all the paint on the outside of the heads is still in perfect shape.
I think if you sprayed the inside of a set of manifolds as far up inside them as possible it might help the resto overspray last a lot longer on a car that will be driven.
Here is a pic I found of a Pontiac engine that shows what typically happens to the engine paint on at the exhaust ports right in front of where the manifolds, or in this case headers, bolt to.
Re: exhaust manifolds, no paint..resto.. [Re: Neil] #1043431
07/30/11 11:49 PM
07/30/11 11:49 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
That's why I thought you could just paint the mounting flanges instead of the entire manifold. The paint doesn't burn off of there anyway. You may be able to re-apply the RPM to the hot manifolds shortly after breakin...before the manifolds start to rust.(covering up any areas where the paint did burn off) This hasn't been tried before so I'm just thinking out loud I guess.
Re: exhaust manifolds, no paint..resto.. [Re: burdar] #1043432
07/31/11 01:39 AM
07/31/11 01:39 AM
MO
cdp Offline OP
cdp  Offline OP
MO
I actually have some RPM and never though to try it on manifolds.
When the time comes to put my A12 motor completely together, I'll probably try RPM. Originally, the plan was to use Jethot, but the more original look was what I'm wanting.
Re: exhaust manifolds, no paint..resto.. [Re: cdp] #1043433
07/31/11 02:25 AM
07/31/11 02:25 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Why not jet hot coat or thermal barrier the inside of the exh manifold and leave the outside natural with gear oil/ecs/ or whatever, anyone ever try this
Re: exhaust manifolds, no paint..resto.. [Re: cdp] #1043434
07/31/11 07:34 AM
07/31/11 07:34 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A LITTLE bit of smoke ... ... it going to all burn off and leave a nasty looking residue on them.
good luck
Re: exhaust manifolds, no paint..resto.. [Re: JohnRR] #1043435
07/31/11 07:15 PM
07/31/11 07:15 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
I use the Easrwoods then let it dry . Later I install them on the engin befor paint and paint over the Eastwood coating and the engin at the same time. Most of the paint will burn off leaving just the eastwood coating and some overspray. The engin in the pic has been already run .
Re: exhaust manifolds, no paint..resto.. [Re: THESHAKERPROJECT] #1043436
07/31/11 07:59 PM
07/31/11 07:59 PM
Berwyn, IL
Moparlar Offline
Moparlar  Offline
Berwyn, IL
This is what I did also.
Larry
Re: exhaust manifolds, no paint..resto.. [Re: Moparlar] #1043437
08/20/11 05:20 PM
08/20/11 05:20 PM
MO
cdp Offline OP
cdp  Offline OP
MO
No pics, but the oil burned off and basically left a nice appearance overall. Not sure it its really protected well.
I oiled down the manifolds and let them set out in the 100 degree heat off and on for a week before installing.
Re: exhaust manifolds, no paint..resto.. [Re: cdp] #1043438
08/20/11 07:27 PM
08/20/11 07:27 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Headers. Less weight. Better sound. Better performance.
Re: exhaust manifolds, no paint..resto.. [Re: DennisH ] #1043439
08/20/11 07:44 PM
08/20/11 07:44 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Headers: Leak, rust, burns wires and starters, coatings never stay on and or turn color...and #1 thing for me... they don't look stock.
Re: exhaust manifolds, no paint..resto.. [Re: cdp] #1043440
08/20/11 07:56 PM
08/20/11 07:56 PM
DennisH Offline
Vacation
DennisH  Offline
Vacation
Reach for your wallet and get TTI's. None of the above.
Re: exhaust manifolds, no paint..resto.. [Re: DennisH ] #1043441
08/21/11 12:17 PM
08/21/11 12:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This doesn't answer the OP's original question , but then again this IS moparts ...
