Tube Bender #1043197
07/30/11 04:11 PM
07/30/11 04:11 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Any one ever use the Eastwood one?
http://www.eastwood.com/professional-tubing-bender.html
Whats your take on it?is it a or on it
Re: Tube Bender [Re: racerx] #1043198
07/30/11 06:04 PM
07/30/11 06:04 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Looks like an awful lot of money for an 8 ton that can only handle less than 2".
You doing a DIY cage?
Re: Tube Bender [Re: Commando1] #1043199
07/30/11 10:31 PM
07/30/11 10:31 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
only 60 degree's and .089 pipe, I don't think so
Re: Tube Bender [Re: rowin4] #1043200
07/30/11 11:29 PM
07/30/11 11:29 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thax's Rowin4 i take it's a on the bender
Commando i presently have a cage in the car,but the hay lo doesn't fit like i think it should so I'm thinking about cutting it out and re doing the halo forward and while I'm at it putting a front snout on the front end when i change the front suspension over to a tubular setup with coil overs next year,just thinking a head Can anyone recommend a decent price one that your average hobbies can afford?
P.S......Any have any pic. of there front snout bars in e-body........Thax.
Re: Tube Bender [Re: racerx] #1043201
07/31/11 01:27 AM
07/31/11 01:27 AM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
check out van saint trick tools. id check out the jd2 benders. a little more money but alot nicer quality
Re: Tube Bender [Re: prochargedhemi] #1043202
07/31/11 01:58 AM
07/31/11 01:58 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
i have a model 32 from jd2 and the manual isnt that bad of a price....but the dyes are pricey
Re: Tube Bender [Re: prochargedhemi] #1043203
07/31/11 03:26 AM
07/31/11 03:26 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
check out van saint trick tools. id check out the jd2 benders. a little more money but a lot nicer quality
Thax.Prochargehemi/Josh 4 that recommendation,i check out that site and it's cool i put it into my favorites so I'll check it out tomorrow.Its getting late I'm off to bed.
Re: Tube Bender [Re: racerx] #1043204
07/31/11 09:34 AM
07/31/11 09:34 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I have a JD2 manual bender also, and like it.
Jeff
69 GTX 68 Road Runner
Re: Tube Bender [Re: JERICOGTX] #1043205
07/31/11 10:50 AM
07/31/11 10:50 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Two ? 1)Can mild steel and chrome molly be welded together reason I'm asking i would like to keep he weight down as much as possible.I know the c/m needs to b tig just wondering if the two can be mated.2)Is there anything in the rule book that states mixing the two types of material....Thax.
Re: Tube Bender [Re: racerx] #1043206
07/31/11 11:08 AM
07/31/11 11:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have been using a Pro-Tools 104 that I upgraded to
a hyd unit... it will do 120* bends and thick wall,
multiple dia tubes
Re: Tube Bender [Re: racerx] #1043207
07/31/11 11:12 AM
07/31/11 11:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes you can attach the mild to moly... BUT that joint
needs to be tigged because you are playing with
moly(at that point)
Re: Tube Bender [Re: racerx] #1043208
07/31/11 11:17 AM
07/31/11 11:17 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Years ago I had a friend install a cage in my car. When I later tried to get it certed the inspecter said I had 2 CM braces that would have to be changed. I don't know if it was because of the welding or the mismatch of metal.
Re: Tube Bender [Re: Blucuda413] #1043209
07/31/11 11:39 AM
07/31/11 11:39 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thax. if it would cause a problem with tech.i'll just keep it all m/s
