Fram filter ID #104290
08/13/08 01:51 PM
08/13/08 01:51 PM
AZ.
Casey Offline OP
Casey  Offline OP
AZ.
Anyone have an old Fram filter catalog? I'm looking for the application of filter # ca-132. It looks similar to a 6pk filter, but doesn't fit the a 6pk a/c housing.
Re: Fram filter ID [Re: Casey] #104291
08/13/08 02:01 PM
08/13/08 02:01 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
www.fram.com
Quick Part Search —
Part Number ca-132 Not Found
Re: Fram filter ID [Re: gtx6970] #104292
08/13/08 03:13 PM
08/13/08 03:13 PM
AZ.
Casey Offline OP
Casey  Offline OP
AZ.
Bill, Thanks for the link. Do you think that part number search would only include presently available filters? I don't believe the filter I have is produced anymore and perhaps this is the reason it doesn't show up in the Fram search. The box my filter is in appears to be the original. It is just a plain brown cardboard construction with the words "Fram ca-132" stenciled onto it. I think it might be for a 64-5 race hemi a/c housing, but want to verify. Any older Fram catalogs out there? How about a race hemi, A-990 web site?
Re: Fram filter ID [Re: Casey] #104293
08/13/08 03:52 PM
08/13/08 03:52 PM
It's a dry heat
It's a dry heat
Not shown very well may be due to being a dis-continued pt #
I may have an old fram listing at home. I'll ck this afternoon and see what, if anything I come up with
is it bigger or smaller than the 6 pack filter?
Re: Fram filter ID [Re: gtx6970] #104294
08/13/08 04:33 PM
08/13/08 04:33 PM
AZ.
Casey Offline OP
Casey  Offline OP
AZ.
Compared to a 6pk filter it is slightly wider at the sides and the front and rear has a more rounded shape to it. The heights are roughly the same.
Re: Fram filter ID [Re: Casey] #104295
08/15/08 10:59 PM
08/15/08 10:59 PM
AZ.
Casey Offline OP
Casey  Offline OP
AZ.
Any suggestions?
Re: Fram filter ID [Re: Casey] #104296
08/16/08 12:23 AM
08/16/08 12:23 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Maybe search on eBay for an old Fram catalog?
Re: Fram filter ID [Re: Casey] #104297
08/16/08 11:06 AM
08/16/08 11:06 AM
It's a dry heat
It's a dry heat
I looked , I do not have any way to cross it. If it's race hemi cross ram, I seriously doubt there was any other manufacturer for this application besides Fram. So there most likely was not any cross reference filters avail in the aftermkt.
You may try the race forum with a picture and dimenensions.
sorry I was no help
Re: Fram filter ID [Re: gtx6970] #104298
08/16/08 11:48 AM
08/16/08 11:48 AM
AZ.
Casey Offline OP
Casey  Offline OP
AZ.
Bill, Thanks for trying. I've never posted any pics here before, not exactly sure how? As far as the filter goes it looks similar to a 6pk filter, just rounder at the front and back. It has the orange rubber with round hole screen on the outside, square mesh on the inside. Its overall length front to back is 21 5/8". Its width is 16 1/4". The height is 2 1/8". Anyone have a race hemi a/c housing lying around?
Re: Fram filter ID [Re: Casey] #104299
07/13/09 11:59 AM
07/13/09 11:59 AM
Colorado, USA
64racehemi Offline
64racehemi  Offline
Colorado, USA
Hello Casey
Do you still have that Fram CA132 air filter?
Re: Fram filter ID [Re: 64racehemi] #104300
07/13/09 12:04 PM
07/13/09 12:04 PM
Colorado, USA
64racehemi Offline
64racehemi  Offline
Colorado, USA
Casey
I have been trying to research this part number for some time. I spoke with the guy's at Fram and they don't have any listing for that part number. Not even in there older catalogs. I do believe it is for a race hemi though and I ne one for my car. I am currently using the K&N replacement that is available by special order but would rather have a correct filter if at all possible.
Re: Fram filter ID [Re: Casey] #104301
07/13/09 12:49 PM
07/13/09 12:49 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
You're dimensions are right on. Here's a pic of an NOS filter and the carter carb base. There are no part numbers on the filter.
Re: Fram filter ID [Re: twodoorpost] #104302
07/13/09 02:31 PM
07/13/09 02:31 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
I have one that is 21 1/2" x 16 1/4" x 3". I haven't been able to find out what it fits.
Here is a comparison between this filter and a 6-Pak Shaker filter.
Re: Fram filter ID [Re: Snoopy] #104303
07/13/09 03:06 PM
07/13/09 03:06 PM
Colorado, USA
64racehemi Offline
64racehemi  Offline
Colorado, USA
I bought a couple like that from a guy that said they were race hemi but they don't fit the aircleaner correctly. One guy told me they were for an International Harvestor tractor.
Re: Fram filter ID [Re: Snoopy] #104304
07/13/09 04:18 PM
07/13/09 04:18 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
The large air filter fits this cowl induction air cleaner that was used on the hemi engine, mainly used on the ARCA speedways, back in the day.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Fram filter ID [Re: hemi71x] #104305
07/13/09 04:23 PM
07/13/09 04:23 PM
hemi71x Offline
hemi71x  Offline
Picture #2
Re: Fram filter ID [Re: hemi71x] #104306
07/13/09 04:27 PM
07/13/09 04:27 PM
hemi71x Offline
hemi71x  Offline
Picture #3
Re: Fram filter ID [Re: hemi71x] #104307
07/13/09 05:05 PM
07/13/09 05:05 PM
Colorado, USA
64racehemi Offline
64racehemi  Offline
Colorado, USA
I have seen another one of these years ago. If you look at the spread between the carbs this fits the two Holley 600 four barrel intake, like the one Mopar Performance selld today. Now that I see this air cleaner again it dispells the rumor that the two holley system was only a marine application. It might have been used that way but this air cleaner clearly shows it was used on a car as well. That three inch height is interesting. I wonder if that's what I have here?
Re: Fram filter ID [Re: hemi71x] #104308
07/13/09 05:06 PM
07/13/09 05:06 PM
Snoopy Offline
Snoopy  Offline
Good information. One mystery solved.
Re: Fram filter ID [Re: hemi71x] #104309
07/13/09 06:54 PM
07/13/09 06:54 PM
hemi71x Offline
hemi71x  Offline
Here is another photo of a NASCAR single 4bbl cowl induction air cleaner that i have in my collection.
Bet ya that's an obsolete air filter element.
