Why Did My Wire Burn Up? #1043057
07/30/11 11:30 AM
07/30/11 11:30 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I was driving my Challenger this morning and I wanted to test the parking lights while I drove around just to make sure everything was running good. But less than five minutes with the parking lights on, smoke rolled out of the dash behind the light switch. When I pulled it apart, one of the wires that "I" made burned up. The jacket burned right off of it. The end connections were not scored and a second wire that was attached to the wire was not burned, just the main wire that is only about 4 inches long.
I assumed that I did something wrong when I made it but I am also wondering if the piece of wire that I used could have been the issue. It was just a loose wire that I had in my wire collection.
This wire was attached to my head light switch on the next reply. The second wire (blue) feeds the light bulb on my A/F gauge and that wire was not affected. All of my turn signals still work so it appears to be just the connection at the switch.
What do you think I did wrong?
Re: Why Did My Wire Burn Up? [Re: YO7_A66] #1043058
07/30/11 11:31 AM
07/30/11 11:31 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
This is where it hooked up.
Re: Why Did My Wire Burn Up? [Re: YO7_A66] #1043059
07/30/11 11:35 AM
07/30/11 11:35 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Too much current for the wire size. A byproduct of current is heat if the gauge is marginal. Too much current, too much heat, hence a meltdown.
Was the new wire for the A/F gauge downstream from the melted wire. If so, you had added the load on the supply wire more than it was design for.
Re: Why Did My Wire Burn Up? [Re: YO7_A66] #1043060
07/30/11 11:37 AM
07/30/11 11:37 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Here are the first few things that come to mind:
1) Those crimp connectors are not the way to make a quality connection but they should handle moderate loads.
2) You used too small of a wire for the load. Remember that all the instrument lights are also carried on the driving light circuit.
3) You failed to use relays to carry the load stated above.
4) There was a short somewhere in the system.
5) You failed to use the proper size fuse in the circuit.
- Stu Harmon
Re: Why Did My Wire Burn Up? [Re: Dean_Kuzluzski] #1043061
07/30/11 11:39 AM
07/30/11 11:39 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Dean,
I did feed the light bulb off of the switch so that when the lights are turned on, my A/F gauge lights up.
I have already made a second wire assembly and the existing 16 or 18 gauge wire that burned up is now a 14 ga wire. Will this fix it?
I also added a 5a fuse on the blue wire going to the A/F gauge. Is this enough or wrong? My existing head light switch wires are now 14ga and they look fine.
Thanks for the reply.
Re: Why Did My Wire Burn Up? [Re: YO7_A66] #1043062
07/30/11 03:58 PM
07/30/11 03:58 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I think you missed the point.
Unless something is wrong with the A/F gauge adding a 5 amp fuse won't fix your problem.
What size fuse do you have supplying power to that switch? If you had enough draw to burn an 18 gauge wire it's still going to be enough power to make a 14 gauge wire hot. You don't want hot.
You shouldn't have more than 15 amps running through a driving light circuit. If that's the same circuit as your headlamps imagine how quickly that line is going to smoke when you add that much more current.
Put the exterior lights on a relay. It will take a bunch of load off that switch and wire.
- Stu Harmon
Re: Why Did My Wire Burn Up? [Re: feets] #1043063
07/30/11 04:02 PM
07/30/11 04:02 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
My headlights do have relays and I added the fuse to the A/F gauge just in case. Is the fuse needed?
Re: Why Did My Wire Burn Up? [Re: YO7_A66] #1043064
07/31/11 02:28 AM
07/31/11 02:28 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
HL power isn't factory fused; it gets battery power via the fuse box on the Batt Buss block. The main power wire (black) at the HL switch is 12awg per factory.
That pic you show; what does it feed besides the aftermarket gauge?
Re: Why Did My Wire Burn Up? [Re: PhillyRag] #1043065
07/31/11 02:38 AM
07/31/11 02:38 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Nothing. My origal hl switch connector had issues several years ago, so I had to remove it and add the yellow 14 ga wires as a patch. I will make this piece heavier than the original.
Re: Why Did My Wire Burn Up? [Re: YO7_A66] #1043066
08/01/11 09:29 AM
08/01/11 09:29 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Can anyone tell me how approximately many amps are in the following headlight circuits on my 70 Challenger:
Parking Lights (mid position on switch):
Parking Lights + head lights:
Parking Lights + head lights + brights:
Thanks a bunch.
Re: Why Did My Wire Burn Up? [Re: YO7_A66] #1043067
08/01/11 10:20 AM
08/01/11 10:20 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
With a two light system on my Cuda headlamps on bright with running lights draws 11 Amps. These are halogen lamps, not the original head lamps that drew a lot more current.
Craig
Re: Why Did My Wire Burn Up? [Re: YO7_A66] #1043068
08/01/11 01:01 PM
08/01/11 01:01 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
A 55 watt headlamp draws 4-1/2 amps. Two of them will pull 9 amps.
a 65 watt high beam light will draw almost 5-1/2 amps. Two will pull 11 amps.
All four headlamps will pull about 20 amps together.
That assumes a perfect world with no losses due to old components, decayed wiring, connections, etc.
Add more for the other lights.
- Stu Harmon
Re: Why Did My Wire Burn Up? [Re: feets] #1043069
08/01/11 01:34 PM
08/01/11 01:34 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Good info Feets. Thanks
Can anyone tell me how many amps the brake circuit and the parking light circuit would pull?
Thanks again.
