Re: Why Did My Wire Burn Up?
[Re: YO7_A66]
#1043058
07/30/11 11:31 AM
07/30/11 11:31 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
This is where it hooked up.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#1043059
07/30/11 11:35 AM
07/30/11 11:35 AM
Posts: 8,940 Holly/MI
Dean_Kuzluzski
Holly/MI
Too much current for the wire size. A byproduct of current is heat if the gauge is marginal. Too much current, too much heat, hence a meltdown.
Was the new wire for the A/F gauge downstream from the melted wire. If so, you had added the load on the supply wire more than it was design for.
[Re: YO7_A66]
#1043060
07/30/11 11:37 AM
07/30/11 11:37 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Here are the first few things that come to mind:
1) Those crimp connectors are not the way to make a quality connection but they should handle moderate loads. 2) You used too small of a wire for the load. Remember that all the instrument lights are also carried on the driving light circuit. 3) You failed to use relays to carry the load stated above. 4) There was a short somewhere in the system. 5) You failed to use the proper size fuse in the circuit.
[Re: Dean_Kuzluzski]
#1043061
07/30/11 11:39 AM
07/30/11 11:39 AM
YO7_A66
Indiana
Dean, I did feed the light bulb off of the switch so that when the lights are turned on, my A/F gauge lights up. I have already made a second wire assembly and the existing 16 or 18 gauge wire that burned up is now a 14 ga wire. Will this fix it? I also added a 5a fuse on the blue wire going to the A/F gauge. Is this enough or wrong? My existing head light switch wires are now 14ga and they look fine. Thanks for the reply.
[Re: YO7_A66]
#1043062
07/30/11 03:58 PM
07/30/11 03:58 PM
feets
Senior Management
Senior Management
Irving, TX
I think you missed the point. Unless something is wrong with the A/F gauge adding a 5 amp fuse won't fix your problem. What size fuse do you have supplying power to that switch? If you had enough draw to burn an 18 gauge wire it's still going to be enough power to make a 14 gauge wire hot. You don't want hot. You shouldn't have more than 15 amps running through a driving light circuit. If that's the same circuit as your headlamps imagine how quickly that line is going to smoke when you add that much more current. Put the exterior lights on a relay. It will take a bunch of load off that switch and wire.
[Re: feets]
#1043063
07/30/11 04:02 PM
07/30/11 04:02 PM
YO7_A66
Indiana
My headlights do have relays and I added the fuse to the A/F gauge just in case. Is the fuse needed? Thanks
[Re: YO7_A66]
#1043064
07/31/11 02:28 AM
07/31/11 02:28 AM
Posts: 1,755 Phila
PhillyRag
Phila
HL power isn't factory fused; it gets battery power via the fuse box on the Batt Buss block. The main power wire (black) at the HL switch is 12awg per factory.
That pic you show; what does it feed besides the aftermarket gauge?
[Re: PhillyRag]
#1043065
07/31/11 02:38 AM
07/31/11 02:38 AM
YO7_A66
Indiana
Nothing. My origal hl switch connector had issues several years ago, so I had to remove it and add the yellow 14 ga wires as a patch. I will make this piece heavier than the original. Thanks
[Re: YO7_A66]
#1043066
08/01/11 09:29 AM
08/01/11 09:29 AM
YO7_A66
Indiana
Can anyone tell me how approximately many amps are in the following headlight circuits on my 70 Challenger:
Parking Lights (mid position on switch): Parking Lights + head lights: Parking Lights + head lights + brights: Thanks a bunch.
[Re: YO7_A66]
#1043067
08/01/11 10:20 AM
08/01/11 10:20 AM
Posts: 1,822 Colorado
denfireguy
Colorado
With a two light system on my Cuda headlamps on bright with running lights draws 11 Amps. These are halogen lamps, not the original head lamps that drew a lot more current. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: YO7_A66]
#1043068
08/01/11 01:01 PM
08/01/11 01:01 PM
feets
Senior Management
Senior Management
Irving, TX
A 55 watt headlamp draws 4-1/2 amps. Two of them will pull 9 amps. a 65 watt high beam light will draw almost 5-1/2 amps. Two will pull 11 amps. All four headlamps will pull about 20 amps together.
That assumes a perfect world with no losses due to old components, decayed wiring, connections, etc. Add more for the other lights.
[Re: feets]
#1043069
08/01/11 01:34 PM
08/01/11 01:34 PM
YO7_A66
Indiana
Good info Feets. Thanks
Can anyone tell me how many amps the brake circuit and the parking light circuit would pull? Thanks again.
