drilling yolk for u bolts? #1042419
07/28/11 11:26 PM
07/28/11 11:26 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
first anyone know right off the size of the bolts in the yoke 8 3/4?
and has anyone ever drilled through the yolk and used the u bolts that has the nuts on back side of the yolk?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: drilling yolk for u bolts? [Re: toplescuda] #1042420
07/28/11 11:30 PM
07/28/11 11:30 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
I have been wanting to do this,too!
Since I stripped one of my bolts and tapped it to the next size.
I don't want to remove the yolk,cuz I'm still using the 489 housing with the crush sleeve.
Saving up for a Dana.
John
Re: drilling yolk for u bolts? [Re: jcastle1] #1042421
07/29/11 09:00 AM
07/29/11 09:00 AM
okla.
O
okie Offline
okie  Offline
O
okla.
My RoadRunner is done this way. Some one had stripped it out so it has the ubolts that go thru it with the nuts on the back. You would just need to drill a size are two bigger than the bolts. I haven't had any trouble with it done this way. Good Luck Ronnie
Re: drilling yolk for u bolts? [Re: toplescuda] #1042422
07/29/11 09:06 AM
07/29/11 09:06 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
The factory bolts are 1/4" fine thread, you'll have to go at least 5/16" for the u-bolts.
Re: drilling yolk for u bolts? [Re: buildanother] #1042423
07/29/11 09:43 PM
07/29/11 09:43 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
Is it possible to drill them while the yolk is still attached under the car?
Re: drilling yolk for u bolts? [Re: jcastle1] #1042424
07/30/11 12:22 AM
07/30/11 12:22 AM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
and,where would you buy the u-bolts?
Is there a part # for them?
John
Re: drilling yolk for u bolts? [Re: jcastle1] #1042425
07/30/11 12:42 AM
07/30/11 12:42 AM
smyrna,tn
draginmopars Offline
smyrna,tn
we bought a bolt and girdle kit (both ends) from summit
for the Rampage.
look at the back side of the yoke.
the small joint yoke
there is not much room
for a nut to fit
they hit the radius of the OD of the yoke
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: drilling yolk for u bolts? [Re: draginmopars] #1042426
08/06/11 01:16 AM
08/06/11 01:16 AM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
Has anybody drilled out the yolk for this conversion?
Would like to start this project as soon as someone chimes in.
Thanks,
John
Re: drilling yolk for u bolts? [Re: jcastle1] #1042427
08/06/11 03:18 AM
08/06/11 03:18 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
nice pic,s but ummmmm. wrong end of the car
when was younger i did drill a yoke and put nuts on backside but that was the large yoke (if i remember right?)and what i got now is small
i just ordered a girdle from mancinni to day so dont have to worry about it
1971 charger
Re: drilling yolk for u bolts? [Re: toplescuda] #1042428
08/06/11 03:38 AM
08/06/11 03:38 AM
smyrna,tn
smyrna,tn
Bolt on yokes-- slip joint drive shaft
Doesn't care which end bolts where
Ha-Ha Racin
Havin Fun 101
Howard
71 360 Dart Swinger
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: drilling yolk for u bolts? [Re: toplescuda] #1042429
08/06/11 08:48 AM
08/06/11 08:48 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have the yokes from my Imp rears.They take U bouls instead of the straps.The U bolts are avaliable at any good parts store.Advanced had them for mine.The girdles can be a major problem.Ive heard of quite a few binding.My son bought a set and they are still in the garage somewhere after 10 years.Rocky
Chrysler Firepower
Re: drilling yolk for u bolts? [Re: therocks] #1042430
08/07/11 08:06 PM
08/07/11 08:06 PM
Wis., USA
Bob_Fromm Offline
Bob_Fromm  Offline
Wis., USA
We have drilled out the yokes for years. Drill the 4 holes out to 1/4" and get some 1/4" fine thread grade 8 allen head cap screws with a lock washer and nut on the back side. They are 2 1/4" long if I remember correct (measure yours to be sure). The allen head is easier to work with for tightening. Use your straps over and it's a pretty cheap upgrade. We have always added a drop of blue or red loctite for extra insurance since we like to "enjoy" our cars at times... You can drill the yoke while on the car, just put the car on jack stands and you can turn the yoke to the bottom for easier drilling.
Re: drilling yolk for u bolts? [Re: Bob_Fromm] #1042431
09/15/11 12:28 AM
09/15/11 12:28 AM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
Anyone have some part numbers for the u-bolts,I'm gonna drill the yolk out in the morning.
Re: drilling yolk for u bolts? [Re: jcastle1] #1042432
09/15/11 02:36 AM
09/15/11 02:36 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Unfortunately, no U-bolts will fit a 7260 or 7290 yoke.
Also, I don't recommend the Moroso U-joint girdles because they are too bulky and often catch on the driveshaft.
Re: drilling yolk for u bolts? [Re: Bob_Fromm] #1042433
09/15/11 06:16 PM
09/15/11 06:16 PM
Is the weak point on the OE straps the straps themselves or the mini bolts that secure them? If it's the bolts then I'd do Bob Fromm's allen head bolt mod
