Drum brake question: what caused this to happen? #104196
08/13/08 11:18 AM
08/13/08 11:18 AM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Hello everyone,
I got my brakes bled (front disc, rear drum) and I was out for a test drive. Coming down my street, I stepped on the pedal and heard a loud bang from the rear and then I had no brakes whatsoever. Fortunately, I was only going about 10 mph.
It turns out the back shoe (I guess it's called the secondary shoe) on the drivers side rear brakes actually came off its notch on the starwheel adjuster.
Does anyone know what caused this to happen? It's pretty unsettling, I don't need this happening to me on the street.
Thanks.
Greg
Re: Drum brake question: what caused this to happen? [Re: GregY] #104197
08/13/08 11:23 AM
08/13/08 11:23 AM
Andrewh Online content
Andrewh  Online Content
That only happens if it is not turned out enough. Basically the drums were not adjusted.
You either do not have self adjusting,(has a little cable that hits a bar that rides on the star wheel) or they were just way out.
Your brakes expand further than the starwheel can maintain contact and it falls out.
Should have had very soft brakes.
Re: Drum brake question: what caused this to happen? [Re: GregY] #104198
08/13/08 11:24 AM
08/13/08 11:24 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Did hold down spring break? Either that or perhaps the adjuster was not seated properly onto the shoe?
Re: Drum brake question: what caused this to happen? [Re: OzHemi] #104199
08/13/08 11:31 AM
08/13/08 11:31 AM
Guess I have seen a spring snap before, but that pushed out the wheel cylinder and dropped all sorts of things into the drum.
Re: Drum brake question: what caused this to happen? [Re: OzHemi] #104200
08/13/08 11:34 AM
08/13/08 11:34 AM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Thanks guys.
The pedal did seem softer than I would have liked. Nothing was broken, so I am going to assume they just weren't adjusted properly.
Re: Drum brake question: what caused this to happen? [Re: GregY] #104201
08/13/08 12:26 PM
08/13/08 12:26 PM
when you go back together spoon em out until they are locked solid then back them off accordingly.
Re: Drum brake question: what caused this to happen? [Re: RapidRobert] #104202
08/13/08 03:26 PM
08/13/08 03:26 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
That's how I adjust them. Back off the adjuster until there is a slight drag from the shoes when spinning the wheel.
