Re: flownrs RHS sb!!!
[Re: sshemi]
#1041976
07/28/11 10:40 AM
07/28/11 10:40 AM
Posts: 2,128 sweden
sshemi
sweden
[Re: sshemi]
#1041977
07/28/11 10:41 AM
07/28/11 10:41 AM
Posts: 2,128 sweden
sshemi
sweden
[Re: sshemi]
#1041978
07/28/11 10:41 AM
07/28/11 10:41 AM
Posts: 2,128 sweden
sshemi
sweden
[Re: sshemi]
#1041983
07/29/11 06:05 AM
07/29/11 06:05 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
So IMM claim 277 @ .600 with a 2.02 valve and a port job Shady gets 296 @ .500 ![](/ubbthreads/images/graemlins/eeek.gif) .... with a slightly bigger valve but less porting , ....would I be out of line if I said thats a cr@pload of unexplained difference???
[Re: Moparmal]
#1041984
07/29/11 08:38 AM
07/29/11 08:38 AM
Posts: 1,051 The Great White North
RAMM
I'm working on a set of EQ Magnum's right now. This will be a fairly serious porting effort IMO so I would be willing to share. Here's some flow data from my last set of EQ Magnum's:
SF-1020 4.03" bore 28" 2.055/1.6 Ferrea's .1 66.3 .2 126 .3 182.2 .4 227 .5 255 .55 262 .6 267 These heads were not "all-out ported" by any means and were targeted for a very hot stock stroke 360 street build. BTW @ 363 cubes, 10-1 comp, hydro-roller, dual-plane, 91 octane, etc.... 478 hp 490 ft/lbs! J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: 67_Satellite]
#1041988
07/29/11 08:52 AM
07/29/11 08:52 AM
Posts: 2,128 sweden
sshemi
sweden
What is the cross sectional area at the smallest point of the push rod pinch? I had always heard that this was the choke point on this type of head. Opening it up there could account for much of the flow increase.
I havent measured it but i did install sleeves in the holes. The p-r holes in these heads are bigger than the production sb head. So i did the sleeves with the same inner dia as a prod head (1/2") Think the p-r holes where 5/8" on these heads. I could have made the port entrance a little bigger but since i have like 10 pairs of the standard felpro gasket at home thats what i used.
[Re: Moparmal]
#1041989
07/29/11 08:54 AM
07/29/11 08:54 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
....would I be out of line if I said thats a [Email]cr@pload[/Email] of unexplained difference???
I don't think it's shady dell (RyanJ) doing the porting, but they were who they were purchased from set up...
different benches, depends on what fixture/clay form was put on the entrance, correction factors for pressure, etc...
I think the .122" bigger bore plate (4.125 vs. 4.030 which is what most guys use for SB heads) probably inflates the numbers by 10cfm due to less valve shrouding.
[Re: patrick]
#1041990
07/29/11 09:39 AM
07/29/11 09:39 AM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
On a head like this, I'm sure 10 cfm is too much to expect. W-7 and up with 2.120"+ valves, I would believe.
![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: S/ST 3040]
#1041991
07/29/11 11:41 AM
07/29/11 11:41 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I absolutely HATE fat short turns! LOL...
I just ported 3 sets of these damn things, with our 2.02 valves and they flow 276@ .500, 285@ .550 and 290@ .600 and then fall back to 287 past .600 lift. That's porting the pinch area, the bowl and guide boss, and laying the short turn back ALOT.
On pump gas 410's we're making around 520's for HP with either hyd. roller cams or solid FT cams, rpm intakes, 950HP's and small TTI headers. Compression is still only 10:1 or 10.2:1.
We'll be building/dyno testing a mild 360 with our RHS heads with no porting in the next 3 weeks so I'll post our findings since there is very little info about smaller engines with the RHS heads. Brian
Brian Hafliger
