Longer lasting roller cam distributor drive gears? #1041550
07/27/11 06:08 PM
07/27/11 06:08 PM
Vallejo, CA
ditchdrift Offline OP
Vallejo, CA
Does anyone know if there are any longer lasting roller cam drive gears out there? I'm doing a solid roller 340 street motor and i have heard the bronze/aluminum gears for the billet steel cams only last from 2000-4000 miles. I know there are polymer and melonized gears for the GM and Ferd motors.
Re: Longer lasting roller cam distributor drive gears? [Re: ditchdrift] #1041551
07/27/11 06:33 PM
07/27/11 06:33 PM
scratchnfotraction Offline
my SB roller cam has the iron gear pressed on to it to run a stock itermed shaft
been in since 07 as a daily driver with the lunati voodoo roller cam
Re: Longer lasting roller cam distributor drive gears? [Re: scratchnfotraction] #1041552
07/27/11 06:36 PM
07/27/11 06:36 PM
Midwest
fuseable Offline
fuseable  Offline
Midwest
Does anyone make a roller cam with a pressed on gear for a Hemi?
Re: Longer lasting roller cam distributor drive gears? [Re: scratchnfotraction] #1041553
07/27/11 07:02 PM
07/27/11 07:02 PM
Vallejo, CA
Vallejo, CA
Hmm, i can tell that this is a one piece billet cam. Yours must be a two piece cam.
Re: Longer lasting roller cam distributor drive gears? [Re: ditchdrift] #1041554
07/27/11 09:20 PM
07/27/11 09:20 PM
maybe not all sb cams are like mine,but IIRC it is billet with a cast iron gear pressed/pined on it.
Re: Longer lasting roller cam distributor drive gears? [Re: scratchnfotraction] #1041555
07/27/11 09:23 PM
07/27/11 09:23 PM
Vallejo, CA
Vallejo, CA
how could that be if the bearing journal is larger?
Re: Longer lasting roller cam distributor drive gears? [Re: ditchdrift] #1041556
07/27/11 10:45 PM
07/27/11 10:45 PM
albemarle, NC
dusterbd13 Offline
dusterbd13  Offline
albemarle, NC
how do you tell if ones going? ive had mine in for about 4k, and it just seems down on power. havent checked timing yet, though.
Michael Crawford CSP 1970 plymouth Duster back under construction: http://www.pro-touring.com/showthread.ph...ouring-makeover 1964 el camino beater shop truck 96403-project-drivabeater-2-0-64-el-camino-this-time
Re: Longer lasting roller cam distributor drive gears? [Re: ditchdrift] #1041557
07/27/11 10:48 PM
07/27/11 10:48 PM
IIRc,the rear end of the cam shaft has a smaller journal than the rest,the iron gear slides over it and is pressed on its journal and the bearing journal in front of it is bigger..ect..
the BB cam journal is to big to press the gear over and they all need the bronze gear as it is an all billet cam.
I could deff see 2 diff colors of metal on my roller cam and could see it was pressed on like they said.
for a piece of mind,i used the drive gear from a stock sb roller cam engine, which stock cams have the gear pressed on also.
I have one on the shelf and will look it over again
Re: Longer lasting roller cam distributor drive gears? [Re: dusterbd13] #1041558
07/27/11 10:51 PM
07/27/11 10:51 PM
you will have to it for wear if your talking the drive gear or cam gear
Re: Longer lasting roller cam distributor drive gears? [Re: scratchnfotraction] #1041559
07/27/11 10:55 PM
07/27/11 10:55 PM
Vallejo, CA
Vallejo, CA
I wonder how i can tell if mine is that way, its an older crane solid roller that has been reground by comp.
Re: Longer lasting roller cam distributor drive gears? [Re: ditchdrift] #1041560
07/27/11 11:04 PM
07/27/11 11:04 PM
a re-grind would do nothing to the gear
check with crane and see what they say,dont recall crane sb roller cams needing the bronze either.
on my lunati it was a light color and the gear was a dark color and kinda had the blueing look from heat treating maybe
might try posting this on the race board also,much more roller guys over there for sure
I see what the stock cam looks
Re: Longer lasting roller cam distributor drive gears? [Re: scratchnfotraction] #1041561
07/27/11 11:28 PM
07/27/11 11:28 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The roller I just got from Lunati is the same - kinda has me curious - can't se why the gear would need any different treatment than the lobes !!
Re: Longer lasting roller cam distributor drive gears? [Re: Stanton] #1041562
07/27/11 11:34 PM
07/27/11 11:34 PM
the iron gear pressed on plays nice with the drive gear
the cam core is billet steel and much harder,will eat the billet/iron gears up in short order.
hence the bronze gear for the BB,it takes the wear and is replaced more often.
the lobes and rollers are billet steel and do well with each other as far as hardness.
I am no guru but this is what I found doing my research for my sb roller cam swap.
what spring do you have for your lunati?
the lunati springs are doubles and need machine work,i went with the comp 901-16 spring and droped them on and swaped the cam with heads on.
the comps drop on and use stock seals and retainers, are with-in 10# of the spring rate of the lunatis and no valve float at 6200 rpm.
I used 5 lunati sb cams with the comp springs now,they work great
had a set of the lunati double springs for a door stop for a while was the only down side on my research
Re: Longer lasting roller cam distributor drive gears? [Re: scratchnfotraction] #1041563
07/27/11 11:35 PM
07/27/11 11:35 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Stock cams do not have the gear pressed on,it's a 1pc cast core. The billet 2pc crane cores a easy to spot, copper between the lobes but not the rear gear/journal area which is not machined,but cast,with a large pin in the end of the bearing journal. Crane is back and has the 2pc cores. If this is a weekend toy/bracket racer just use the cam you have and check the drive gear every year. Some last for years and I'd avoid Comp cams for this item.
Re: Longer lasting roller cam distributor drive gears? [Re: ditchdrift] #1041564
07/28/11 02:39 AM
07/28/11 02:39 AM
Seattle WA
RichV Offline
RichV  Offline
Seattle WA
Poly gears are available for small block Chrysler. One of the NASCAR engine builders has them.
Re: Longer lasting roller cam distributor drive gears? [Re: ditchdrift] #1041565
07/28/11 03:57 AM
07/28/11 03:57 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I don't know about the small blocks with roller cams, but when I pulled my 451 "B" block apart, that had a solid roller cam, the bronze gear on the oil pump/dist drive looked fine and it had at least 20,000 miles on it.
Re: Longer lasting roller cam distributor drive gears? [Re: ditchdrift] #1041566
07/28/11 09:21 AM
07/28/11 09:21 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
OEM hydraulic roller cams use a steel dist drive gear....I can't remember if my OEM roller cam had a separate pressed on gear or not, or if the core is cast...
2017 Grand Cherokee Overland
Re: Longer lasting roller cam distributor drive gears? [Re: 451Mopar] #1041567
07/28/11 10:53 AM
07/28/11 10:53 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I am running a locking collar on my distributor shaft to help keep not only the timing steady, but also to keep the bronze gear down where it's suppossed to be, in the hopes it will lengthen it's life.
I'm wondering if having the indermediate shaft and gear cryogenically treated will help it last longer.
