Flipping Spring Hangers to Lower the Ride Height? #104137
08/13/08 01:58 AM
08/13/08 01:58 AM
Los Angeles, CA
Mobarge Offline OP
Mobarge  Offline OP
Los Angeles, CA
I've got a '71 B-Body, and I'd like to lower the rear ride height by about 1 inch. In looking at my factory stock hangers on the front of the rear springs, it looks like I can flip them (so the hanger hole is higher / closer to the undercarriage), which I believe will lower the car. Has anyone done this? How much does this lower the car? Anything to watch out for?
'71 SSP - SOLD!
Re: Flipping Spring Hangers to Lower the Ride Height? [Re: Mobarge] #104138
08/13/08 02:09 AM
08/13/08 02:09 AM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
I've heard of it before. You can try it to see if it works out for you.
As you move the height, for every two-inches on one fixed-end (front or rear) you get 1-inch change in ride-height.
If it's time for new springs (old ones worn out) you could order a new ride height set or have the old springs de-arched.
Lowering-Blocks (mounted between the spring-pads and spring) are another option.
Re: Flipping Spring Hangers to Lower the Ride Height? [Re: D_C] #104139
08/13/08 02:11 AM
08/13/08 02:11 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
What would raising the front of the springs (flipping the hanger) do to the pinion angle?
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Flipping Spring Hangers to Lower the Ride Height? [Re: 69L78Nova] #104140
08/13/08 02:18 AM
08/13/08 02:18 AM
D_C Offline
D_C  Offline
Always a good idea to check that (pinion-angle) whenever you mess with the springs and ride-height.
If a problem (angle) is detected, you can often fix/adjust with wedge-shims unless it is excessive, in which case you'd need to cut-off/weld-on new spring perch pads onto the rear-axle housing.
Here is some info on checking D/S angles:
http://www.streetrodderweb.com/tech/0203sr_drive_shaft_angles/index.html
Re: Flipping Spring Hangers to Lower the Ride Height? [Re: D_C] #104141
08/13/08 02:23 AM
08/13/08 02:23 AM
Los Angeles, CA
Mobarge Offline OP
Mobarge  Offline OP
Los Angeles, CA
The pinion angle is my biggest concern - I think I'd have to shim it for sure. I don't think I'd be lowering it enough to have to re-weld the perches though. Also, the springs are the XHD Mopar Performance springs.
Does anyone know where to get good solid-steel lowering blocks with the correct U-bolts? I checked Summit, Jegs, Mancini Racing and haven't really found the right set for a '71 B.
'71 SSP - SOLD!
Re: Flipping Spring Hangers to Lower the Ride Height? [Re: Mobarge] #104142
08/13/08 02:42 AM
08/13/08 02:42 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I don't think the pattern is exactly 100% symetrical. IIRC, you have to rat tail file the holes a little??
Re: Flipping Spring Hangers to Lower the Ride Height? [Re: autoxcuda] #104143
08/13/08 06:09 AM
08/13/08 06:09 AM
Spring Hill, Fl.
tecmopar Offline
tecmopar  Offline
Spring Hill, Fl.
When you flip them the holes don't line up so theres some work to be done on that. I do remember using a set of Rancho (I think) aluminum blocks and with a little massaging and longer bolts they worked out great. I don't remember where I got them from though, it was a while back. good luck.
Re: Flipping Spring Hangers to Lower the Ride Height? [Re: tecmopar] #104144
08/13/08 07:17 AM
08/13/08 07:17 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Correct, you have to elongate the holes in the mounting a very minor amount - an easy job and does not stop you reversing it back again. I did it on my Challenger, worked fine.
Alternatively if you prefer to spend money or to not elongate the holes you can now buy bolt-in brackets that have several sets of holes...can't remember where to get them but no doubt someone else will.....
Re: Flipping Spring Hangers to Lower the Ride Height? [Re: Mobarge] #104145
08/13/08 10:01 AM
08/13/08 10:01 AM
AndyF Offline
AndyF  Offline
You can just order new hangers from Mancini Racing rather than butcher up the mounting holes. AR094 will give you a second set of lowering holes. Or, if you really want to drop the car get the AR098 hangers.
You might want to order the reinforcement plates at the same time.
Re: Flipping Spring Hangers to Lower the Ride Height? [Re: AndyF] #104146
08/13/08 10:09 AM
08/13/08 10:09 AM
scratchnfotraction Offline
I thought they went on upside down and swap sides to do that?
Re: Flipping Spring Hangers to Lower the Ride Height? [Re: scratchnfotraction] #104147
08/13/08 11:36 AM
08/13/08 11:36 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i flipped the front hangers about 5 years ago without any problems that i can remember.
this is what it looks like with 5 year old mopar performance hemi springs.
i am not sure the of the height of the tire. it has the STOCK 17" tire from a 08 mustang GT. 31" if i remember correctly.
perception is 90% of reality
Re: Flipping Spring Hangers to Lower the Ride Height? [Re: scratchnfotraction] #104148
08/13/08 01:32 PM
08/13/08 01:32 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
I did that with my Cuda, I was doing a spring relocation and used the A body front hangers (they don't list offset E body hangers for stock spring length)
Re: Flipping Spring Hangers to Lower the Ride Height? [Re: Mr T2U] #104149
08/13/08 01:54 PM
08/13/08 01:54 PM
Los Angeles, CA
Mobarge Offline OP
Mobarge  Offline OP
Los Angeles, CA
Love the ride height on Mr T's '72. So, if I get this right: if I flop sides on the hangers, and turn them upside down, that should work. I may have to tap the holes out a bit though.
'71 SSP - SOLD!
Re: Flipping Spring Hangers to Lower the Ride Height? [Re: Mobarge] #104150
08/14/08 07:30 AM
08/14/08 07:30 AM
London, England
Gavin Offline
Gavin  Offline
London, England
You don't need to swap them side to side
