How do you keep oil out of hemi plug tubes? #1041323
07/27/11 11:00 AM
07/27/11 11:00 AM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
When I change the spark plugs, oil seeps into the cylinders from around the tubes. How do I stop this from happening?
Chris from New Jersey
Re: How do you keep oil out of hemi plug tubes? [Re: fig426] #1041324
07/27/11 11:57 AM
07/27/11 11:57 AM
California
mickm Offline
mickm  Offline
California
there are inserts that fit into the holes in the head at each plug that rise above the head like a cup, and then the tube slides into the insert. i have them on mine, and they work great. keep at least 90% of the oil out. i got mine from a guy on ebay, but it was a while ago. just try a search on ebay with variations on "426 hemi spark plug tubes" and you should find them.
or i would assume someone like mancini would have them, there are a number of people out there who make them.
Re: How do you keep oil out of Hemi plug tubes? [Re: mickm] #1041325
07/27/11 12:54 PM
07/27/11 12:54 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Summit has them, but they are a bit expensive, $150.
Re: How do you keep oil out of hemi plug tubes? [Re: mickm] #1041326
07/27/11 01:26 PM
07/27/11 01:26 PM
Arizona
az426john Offline
az426john  Offline
Arizona
How are they installed? Do you have to have them pressed in by a machine shop?
Re: How do you keep oil out of hemi plug tubes? [Re: az426john] #1041327
07/27/11 01:31 PM
07/27/11 01:31 PM
englewood beach, florida
ts70rt Offline
ts70rt  Offline
I tapped mine in using a socket
Re: How do you keep oil out of hemi plug tubes? [Re: az426john] #1041328
07/27/11 07:27 PM
07/27/11 07:27 PM
NASHVILLE
MAVERICKSHEMI Offline
NASHVILLE
Also the proper "O" ring is important even if you have the cups. The only ones that work for me is John Arruza,s sales them,, He also has a great V/C gasket. thick. lube the tube some when you slide them on. Wont damage Ring. I will ask this, Does ur spark plugs have the crush washer on them? If they do you will have oil every place.
Keep it outta the Ditches!
Re: How do you keep oil out of hemi plug tubes? [Re: MAVERICKSHEMI] #1041329
07/27/11 11:37 PM
07/27/11 11:37 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
I like the cup idea. As for orings, they seem to fit well, and as for gaskets on the plugs, yes there are gaskets. Should I not have the gaskets on the plugs?
Re: How do you keep oil out of hemi plug tubes? [Re: fig426] #1041330
07/28/11 12:06 AM
07/28/11 12:06 AM
NASHVILLE
NASHVILLE
Cut them off or get another set of A/C,s without Washers. I cut off one time for a guy with a good pair of side cutters, They mean lil boogers..
Re: How do you keep oil out of hemi plug tubes? [Re: MAVERICKSHEMI] #1041331
07/28/11 12:19 AM
07/28/11 12:19 AM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Whats the purpose of cutting them off?
Re: How do you keep oil out of Hemi plug tubes? [Re: Snoopy] #1041332
07/28/11 12:35 AM
07/28/11 12:35 AM
California
mickm Offline
mickm  Offline
California
it was a while ago, but i didn't pay near that much for them. search around and you can find a better deal.
Re: How do you keep oil out of hemi plug tubes? [Re: fig426] #1041333
07/28/11 12:54 AM
07/28/11 12:54 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Dont use the washers, cutting them off is harder than just unscrewing them.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: How do you keep oil out of hemi plug tubes? [Re: HemiRick] #1041334
07/28/11 05:35 AM
07/28/11 05:35 AM
NASHVILLE
NASHVILLE
We could not get them to screw off after they was crushed.
Reason for takeing off get a better seal on the Tube. Washers are made to seal on a conicle spark plug hole.
Re: How do you keep oil out of hemi plug tubes? [Re: MAVERICKSHEMI] #1041335
07/28/11 09:53 AM
07/28/11 09:53 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
The spark plug washers have to be removed because they cut or chew up the tubes during plug installation causing damage. Just unscrew them off and use the plug base to seat the plug against the plug tube.
logan426
Re: How do you keep oil out of hemi plug tubes? [Re: MLR426] #1041336
07/28/11 10:29 AM
07/28/11 10:29 AM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Thanks all!!
Re: How do you keep oil out of hemi plug tubes? [Re: fig426] #1041337
07/28/11 02:08 PM
07/28/11 02:08 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Here are a few pictures of them installed.
Re: How do you keep oil out of hemi plug tubes? [Re: 68jim] #1041338
07/28/11 02:09 PM
07/28/11 02:09 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
#2
Re: How do you keep oil out of hemi plug tubes? [Re: 68jim] #1041339
07/28/11 04:06 PM
07/28/11 04:06 PM
PNW
Danan Offline
Danan  Offline
PNW
BTW, the inserts will not fit the aluminum E-brock/MP heads without machining the heads. It's a simple cut that needs to be made with a mill. They fit original heads perfectly. Milodon makes (made?) the inserts as well, but I bought two sets from the guy on Ebay and have had no problems. I think I paid about $90 for them, but it was several years ago..
Re: How do you keep oil out of hemi plug tubes? [Re: fig426] #1041340
07/28/11 11:56 PM
07/28/11 11:56 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Also I don't pull the sparkplug tubes out if I'm just changing the plugs. I unscrew them and then shove a length of fuel hose down there to grip the plug and pull it out. Same with installing the plugs, I gently guide them down on the end of the hose and spin them in by twisting the hose before torquing.
Sheldon
