4.7 swap into 77 dodge truck Thoughts?
#1040286
07/26/11 03:07 AM
07/26/11 03:07 AM
Posts: 478 Brady Mt Big Sky Country
72roadrunner
super gas
super gas
I have a complete 03 4.7 durango 2wd that was rolled, and was thinking about putting it into a 77 dodge short box project that I have. Am I just dreaming or nuts? I want to do something different, I really wanted to go with a 4cyl cummins but, I have a low mile 4.7
Conrad Salvage & Recycling 406-278-7909
Re: 4.7 swap into 77 dodge truck Thoughts?
[Re: dogdays]
#1040288
07/26/11 02:15 PM
07/26/11 02:15 PM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I LOVE the 4.7 in my 2002 Ram. Wish there was more aftermarket support too. If you have the entire powertrain nad all the wiring and computer I say go for it!!! Its a good running strong engine.
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
[Re: 72roadrunner]
#1040289
07/26/11 07:05 PM
07/26/11 07:05 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You might want to get with someone very familiar with how Chrysler's computers are integrated in that truck, some of them are real tricky,
[Re: Supercuda]
#1040290
07/26/11 07:49 PM
07/26/11 07:49 PM
Our 2001 Grand Cherokee 2wd is a 4.7 It is hands down the best street engine I have ever had--STRONG from a stoplight--excellent throttle response and perfect power curve and...21 MPG on a trip --never any worse than 19 no matter what--have never towed with it but just love the total package--have about 140K on it and so far so good. I would love one in an older 60's model Dart or Valiant--may do it one day
[Re: TX9H6E4CUDA]
#1040292
07/27/11 12:57 AM
07/27/11 12:57 AM
72roadrunner
super gas
super gas
Its a complete running 70,000 mile durango,,,just was rolled on its side in a snow storm. (not by me) My wife has bad back problems and cant get into or out of my plymouth so I want to fix the 77 to look like a little red express, with some kind of powered seats for her. I figure if I put the 4.7 in it, she may even beable to drive it.
I cant find any info yet on wirring yet. Any sugestions?
[Re: dogdays]
#1040296
07/27/11 12:18 PM
07/27/11 12:18 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Dude - that's going to be a tough convertion. I'm converting a 1975 Trail Duster to a 1993 360 MPI out of a 1993 Ram Charger. I am upgrading 18 years and staying withing the same body style. I solved my electrical by switching out dashes.
Here is all the stuff I swapped over to make it work - gas tank, fuel lines, all electrical (still needing modification, exhaust, dash, heater, wiper motor, brake booster, steering box, radiator and so on.
Good luck
[Re: 72roadrunner]
#1040297
07/27/11 08:26 PM
07/27/11 08:26 PM
dogdays
[Re: ahy]
#1040300
07/27/11 09:50 PM
07/27/11 09:50 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
My opinion. The 4.7 is a very good engine and can be in high demand because there do not seem to be as many of them produced as 5.2 and 5.9 magnum engines. Depending on whether cost is an issue or not, but you might be lucky and find that a running 4.7 engine would bring a good price on something like craigslist. It is definitely do able.
Look for an a service manual, and in the back they have a system wiring diagram that would be your best friend on how to do the wiring. The dash cluster, etc, is not needed to make this work. Just need the right fuel psi, PCM (without security), and probably a manual trans PCM would be preferred.
Good luck with the project!
Justin
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
[Re: sthemi]
#1040302
07/27/11 11:54 PM
07/27/11 11:54 PM
wldtm
Dayton, Ohio
You are going to need a rear axle with a tone ring and pickup mounting for the sensor, probably will need to use the durango rear end, or newer pick up. The sensor is a must have for the tranny and engine computer to work.
I think it will be fine without. You may need to send it to B&G for flash, but there are easier ways to do this, IMO. Swapping the axle and tone wheel are NOT essential to do this engine swap.
Justin
PM for details
[Re: wldtm]
#1040303
07/28/11 02:14 AM
07/28/11 02:14 AM
72roadrunner
super gas
super gas
yea,,,I thought about the rear diff,,, figured it was the least of my problems. One from a 93 will fit right in and I have one, I think it would work. but again its the least of my problems
