no spark #1040271
07/26/11 12:24 AM
07/26/11 12:24 AM
DELAWARE
68moparmike Offline OP
DELAWARE
when i turn my key on i get one spark and when i turn key off i get one spark..change ignition switch no help noticed coil getting hot so i changed it car started right up tryed couple times and same thing coil hot and only one spark again,,,,an ideas?
Re: no spark [Re: 68moparmike] #1040272
07/26/11 02:02 AM
07/26/11 02:02 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
does coil fail,try checking ballast to see correct ohms resistance ,starter relay is it good.
Re: no spark [Re: moparsquid] #1040273
07/26/11 08:28 PM
07/26/11 08:28 PM
DELAWARE
DELAWARE
put new coil and ballist on today ran for about 2 minutes then shut off and ballist smoked
Re: no spark [Re: 68moparmike] #1040274
07/26/11 08:48 PM
07/26/11 08:48 PM
Some new ballasts will smoke when 1st fired up. I would space it away from flush w the firewall. See if it'll start tomorrow
Re: no spark [Re: RapidRobert] #1040275
07/26/11 08:55 PM
07/26/11 08:55 PM
DELAWARE
DELAWARE
o ok cool i hope so
Re: no spark [Re: 68moparmike] #1040276
07/26/11 09:18 PM
07/26/11 09:18 PM
scratchnfotraction Offline
check the fuseable link for ign also
Re: no spark [Re: scratchnfotraction] #1040277
07/26/11 09:32 PM
07/26/11 09:32 PM
DELAWARE
DELAWARE
i cant find one it is a 1960 my guess is it must not have it
Re: no spark [Re: 68moparmike] #1040278
07/26/11 09:37 PM
07/26/11 09:37 PM
I was thinking 68
Re: no spark [Re: scratchnfotraction] #1040279
07/26/11 09:51 PM
07/26/11 09:51 PM
DELAWARE
DELAWARE
I was thinking 68
no my other three cars are 68 though
