440 and auto into 88 4x4 ramcharger??? #1039471
07/24/11 11:00 PM
07/24/11 11:00 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
ok i know there is something differnt about the frame so it wont just bolt up....but...dont matter as i have a steel front motor plate and this is more of a off road beater lol
that being said what tranny do i need to look for to go with what ever kind of transfer case? long or short shaft? no biggie if i have to fab a tranny mount or crossover
mostly just need to know what i need a tranny out of lol
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: 440 and auto into 88 4x4 ramcharger??? [Re: toplescuda] #1039472
07/24/11 11:36 PM
07/24/11 11:36 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
easy conversion grasshopper
a 440 (w/alt, brackets ect)
a set of 400440 engine mounts (the metat ones)
400/440 exhaust manufolds or headers
a 400/440 4x4 trans
hopefully your truck isnt a TBI truck,,, that changes everything...
I am truckless..
Re: 440 and auto into 88 4x4 ramcharger??? [Re: 340SHORTY] #1039473
07/25/11 11:51 AM
07/25/11 11:51 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Isn't there something about the brake booster too?
I agree that bolting one in should be fairly easy with truck parts. It's all the little and not so little stuff around and supporting that will be more time and money.
Radiator
Exhaust
minor wiring
PS pump
The booster
Re: 440 and auto into 88 4x4 ramcharger??? [Re: RodStRace] #1039474
07/25/11 03:06 PM
07/25/11 03:06 PM
scratchnfotraction Offline
yes,use a 86 3/4 ton small vac booster or do a plate for manual brakes
change wire harnes to an 85 so it can be worked and have the VR for charging.
one side of frame may not let you boult a BB in,mine would not,so I swaped to 85 frame along with 85 harness for my 88 truck.
you need the BB 727 short shaft that has the 4x4 output shaft and the trans to xfer adaptor which has the tall mount built in,you need the 4x4 xmember also
if you use a motor plate bolt the tranz up in stock location and set the engine/frame/plate
Re: 440 and auto into 88 4x4 ramcharger??? [Re: RodStRace] #1039475
07/25/11 03:11 PM
07/25/11 03:11 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
yes its a tbi that dont worry me as that is easy to take care of
is 4x4trans same as a truck trans? what about a short shaft trans out of a motor home ,yea the parking brake has to come off
could of swore someone was saying hard to put in without a lot of fab work cause a change of the frame
i was thinking this ramcharger had overdrive will a 727 bolt up?
1971 charger
Re: 440 and auto into 88 4x4 ramcharger??? [Re: toplescuda] #1039476
07/25/11 05:18 PM
07/25/11 05:18 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
You'll probably have to modify the crossmember to work.
You can use motor mounts - you need BB 4x4 - the BB 2WD won't work
