Harmonic damper for SB stroker...
#103894
08/12/08 05:16 PM
08/12/08 05:16 PM
Posts: 32 Portland, Or.
Bee4spd
Portland, Or.
I was looking at budget street dampers on the Summit web sight and found a Pioneer damper that sounded more interesting than the rest. It is of a tad smaller diameter and lower weight than the rest of their product line(p/n pio-872054). I was wondering first if any of you have used this damper? And second it would seem that there should be an advantage to using this damper since it's lighter and of smaller diameter. Your thoughts and advice are appreciated. Oh, the engine is 340 based stroker(414), torque oriented build.
Re: Harmonic damper for SB stroker...
[Re: 69Cuda340S]
#103899
08/13/08 09:22 AM
08/13/08 09:22 AM
Posts: 549 CT
340KID
CT
[Re: 340KID]
#103900
08/13/08 10:51 AM
08/13/08 10:51 AM
just a warning. I saw a guy at the drags thew other night who had a brand new harmonic balancer break apart and take out his radiator and sent pieces THRU his fender. I could have sworn he said it was a pioneer but im not sure
#103901
08/13/08 11:57 AM
08/13/08 11:57 AM
Posts: 5,895 Florida
Locomotion
Regardless of brand....was it an SFI approved unit and was he fast enough to require one? Was it installed correctly and/or modified in any way?
I've been using a neutral balanced SFI unit from Pioneer, also available from Jeg's under their label, for years without problems, externally or internally!
[Re: Locomotion]
#103902
08/13/08 03:56 PM
08/13/08 03:56 PM
Triple Threat
Renton Washington
I have the Summit SFI dampner on my 340, my machinist said it was a good piece for the price. Haven't had any issues with it. 70 passes so far this year and a couple thousand street miles.
