Harmonic damper for SB stroker... #103894
08/12/08 05:16 PM
08/12/08 05:16 PM
Portland, Or.
Bee4spd Offline OP
Bee4spd  Offline OP
Portland, Or.
I was looking at budget street dampers on the Summit web sight and found a Pioneer damper that sounded more interesting than the rest. It is of a tad smaller diameter and lower weight than the rest of their product line(p/n pio-872054). I was wondering first if any of you have used this damper? And second it would seem that there should be an advantage to using this damper since it's lighter and of smaller diameter. Your thoughts and advice are appreciated. Oh, the engine is 340 based stroker(414), torque oriented build.
Re: Harmonic damper for SB stroker... [Re: Bee4spd] #103895
08/12/08 11:05 PM
08/12/08 11:05 PM
Portland, Or.
Bee4spd Offline OP
Bee4spd  Offline OP
Portland, Or.
BTT
Re: Harmonic damper for SB stroker... [Re: Bee4spd] #103896
08/12/08 11:07 PM
08/12/08 11:07 PM
Spartanburg SC
MoparDan Offline
MoparDan  Offline
Spartanburg SC
I have one on my 416 internal balance stroker. no problems, quality part.
Re: Harmonic damper for SB stroker... [Re: MoparDan] #103897
08/12/08 11:16 PM
08/12/08 11:16 PM
Portland, Or.
Bee4spd Offline OP
Bee4spd  Offline OP
Portland, Or.
Thanks for the reply.
Brian
Re: Harmonic damper for SB stroker... [Re: Bee4spd] #103898
08/13/08 06:42 AM
08/13/08 06:42 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I bought the MP thin a engine damper, part # 4452816. Same dimensions as factory damper so no pulley alignment issues. The lowest price I saw was at www.mopartsracing.com.
Re: Harmonic damper for SB stroker... [Re: 69Cuda340S] #103899
08/13/08 09:22 AM
08/13/08 09:22 AM
CT
3
340KID Offline
340KID  Offline
CT
Re: Harmonic damper for SB stroker... [Re: 340KID] #103900
08/13/08 10:51 AM
08/13/08 10:51 AM
just a warning. I saw a guy at the drags thew other night who had a brand new harmonic balancer break apart and take out his radiator and sent pieces THRU his fender. I could have sworn he said it was a pioneer but im not sure
Re: Harmonic damper for SB stroker... #103901
08/13/08 11:57 AM
08/13/08 11:57 AM
Locomotion Online content
Locomotion  Online Content
Regardless of brand....was it an SFI approved unit and was he fast enough to require one? Was it installed correctly and/or modified in any way?
I've been using a neutral balanced SFI unit from Pioneer, also available from Jeg's under their label, for years without problems, externally or internally!
Re: Harmonic damper for SB stroker... [Re: Locomotion] #103902
08/13/08 03:56 PM
08/13/08 03:56 PM
Renton Washington
Triple Threat Offline
Renton Washington
I have the Summit SFI dampner on my 340, my machinist said it was a good piece for the price. Haven't had any issues with it. 70 passes so far this year and a couple thousand street miles.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Harmonic damper for SB stroker... [Re: Bee4spd] #103903
08/14/08 11:42 AM
08/14/08 11:42 AM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
I used the Summit's brand damper (p/n sum-c4277) on my 340/416 stroker build. Nice piece. The crank is a Scat cast crank which resulted in an external balance. In my case, the counterweight (sum-65278) kit was also needed and a flexplate with additional off-set weights were required.
I was hoping to do what you're suggesting and get away with a lighter damper etc. However, it didn't end up being the case in my build. I think you are pretty much dictated by what your machinist suggest.
Re: Harmonic damper for SB stroker... [Re: cruzin] #103904
08/14/08 12:57 PM
08/14/08 12:57 PM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
Sorry for the slight hijack - but do you have a pic of this damper? The pic on Summit's website looks generic (or maybe I'm wrong).
Thanks,
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
