Lakewood Bellhousing On Small Block #1038531
07/23/11 03:49 PM
07/23/11 03:49 PM
dusterjp Offline OP
dusterjp  Offline OP
Has anyone installed a Lakewood bellhousing on a Duster with a small block before. What are the potetial problems. It has TTI headers and ihas a Center Force clutch and Center Force steel flywheel. Thanks for all advice.
Re: Lakewood Bellhousing On Small Block [Re: dusterjp] #1038532
07/23/11 04:34 PM
07/23/11 04:34 PM
albemarle, NC
dusterbd13 Offline
dusterbd13  Offline
albemarle, NC
i know this has been covered before, as i asked it years ago.
for the TTI's, you WILL have to cut clearance in the passengers side of the beel, at the 4-5 o clock position. gotta cut the block plate there too.
z-bar sometimes needs some tweaking with the lakewood. its also pretty tight on my duster around the bellhousing area. not a lot of room to work.
i actually have to pull mine this winter, and im wondering if i can do it with the motor in the car. just dont know if it will clear.
michael
Michael Crawford CSP 1970 plymouth Duster back under construction: http://www.pro-touring.com/showthread.ph...ouring-makeover 1964 el camino beater shop truck 96403-project-drivabeater-2-0-64-el-camino-this-time
Re: Lakewood Bellhousing On Small Block [Re: dusterbd13] #1038533
07/23/11 09:56 PM
07/23/11 09:56 PM
dusterjp Offline OP
dusterjp  Offline OP
Thanks for the reply.
Re: Lakewood Bellhousing On Small Block [Re: dusterjp] #1038534
07/24/11 12:39 AM
07/24/11 12:39 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I used to have one in a 340 Swinger. You can get it out once the trans is out, but it isn't a lot of fun. Also, if you hear a creaking/grinding noise when you hit a bump, bend over the seam in the tunnel next time you have the bellhousing out.
Re: Lakewood Bellhousing On Small Block [Re: slantzilla] #1038535
07/24/11 06:41 PM
07/24/11 06:41 PM
albemarle, NC
dusterbd13 Offline
dusterbd13  Offline
albemarle, NC
im going to have to look at that. been wondering where that was coming from.
