PRW rocker oil ? #1037081
07/21/11 01:34 AM
07/21/11 01:34 AM
MN
hemidup Offline OP
hemidup  Offline OP
MN
Finished up a 440 Source heads with PWR rockers and a Comp Cams swap today. While priming the engine, fricking oil shot out from every hole from the PRW rocker arm holes about 8 feet with 35 psi on the gauge and soaked my kid down with oil. You should have seen the look on his face. lol Priceless.
Anywho, is this normal since there's no needle bearings? I've never seen anything like this before. Basically its more of an oil hemoridge than anything.
Scarded to fire it up tomorrow for the cam break in.
Jerry Williams.
Re: PRW rocker oil ? [Re: hemidup] #1037082
07/21/11 02:29 AM
07/21/11 02:29 AM
Sounds like it is time for some oil restrictors in the oil galleys or in the heads to limit the oil volume to the rockers, are you oiling the rockers full time or did this only occur when turning the motor over to where the cam let oil go up to the rockers?If oiling full time restrict it, if not don't
Re: PRW rocker oil ? [Re: hemidup] #1037083
07/22/11 03:30 AM
07/22/11 03:30 AM
San Diego
formula S Offline
formula S  Offline
San Diego
I used these rockers on a very mild 360 and the same thing happend except the part about the soaked kid, it looked like a lawn sprinkler when I primed the motor
