Ebody - Center Speaker Grille Fitment Question
#103707
08/12/08 11:00 AM
08/12/08 11:00 AM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
Does the center speaker grille have a slight bow to it naturally or are the two original ones I have warped from the sun? I have a UR refinished dash and when I put the grille on, it has more bow than the dash.
Thanks. Joe
65 Barracuda 70 Challenger
Re: Ebody - Center Speaker Grille Fitment Question
[Re: jrwoodjoe]
#103710
08/12/08 02:34 PM
08/12/08 02:34 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Thanks. Joe
Mine crumbled before it warped. I have two replacements, one aftermarket and one NOS and they are both flat Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: cataclysm80]
#103712
08/12/08 03:15 PM
08/12/08 03:15 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
Sometimes you can flatten them back out with a heat gun. It's worth a shot, and better than throwing it away, especially if it's not busted.
FYI: 70 challenger grill is different from the others... two of the "legs" are a little shorter so that it fits the 70 challenger dashpad. Other E body grills can be converted to 70 challenger style by shortening those legs.
Tav
I may try that TAV before I pull the trigger on a new one. 1 of the one's I have that is in very good shape is the later style. The 70 I have is nice but has a cracked corner. I may try heating the 70 as a test to see how it works and if does then I'll do the other one.
Thanks, Joe
[Re: BigMoneyLewis]
#103714
08/13/08 09:38 AM
08/13/08 09:38 AM
Posts: 4,570 Motor City
6PKRTSE
Motor City
I need a new one for my 70' also. Wasn't someone making these out of billet aluminum.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
