Page 3 of 3 1 2 3
Re: Superbird Overheats [Re: Bayou_Bird] #1037034
07/22/11 05:38 PM
07/22/11 05:38 PM
Eastern shore, New England
roadrunner69s Offline
Good to hear things are improving. Don't leave that straight hose water in the system for too long. Replace it with demineralized water at some point to minimize chemical deposition. You don't want a nice fresh core getting caked up with carbonates. I used to work at a place that had large demin tanks so bringing home a 5 gallon jog of Demin water whenever it was needed was a snap. Maybe you know a friend who works at a company that purifies the incoming city/well water (power plants, boiler houses, waste to energy plants, etc.)
RR69s
Re: Superbird Overheats [Re: roadrunner69s] #1037035
07/22/11 06:38 PM
07/22/11 06:38 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
RR69s
Wouldn't "distilled water" be the same or good to use? You can get distilled water in just about any grocery store or pharmacy, etc,. We used only distilled water (no coolant) in our water cooled motorcycle engines that had magnesium engine cases and water pumps since the early '80's and never had a problem.
MikeR
Re: Superbird Overheats [Re: Bayou_Bird] #1037036
07/23/11 12:46 AM
07/23/11 12:46 AM
Slidell, La.
doctor_mopar Offline
Slidell, La.
You think your Orthopedist is expensive for an office visit.............wait till you get the Mopar Doctors bill for a housecall !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Superbird Overheats [Re: hemi68charger] #1037037
07/23/11 09:35 AM
07/23/11 09:35 AM
Slidell, LA
Bayou_Bird Offline OP
Slidell, LA
Thanks Troy, Yes that is a pic of my engine compartment. Under recommendation of "The Mopar Doctor" I am going to put back the 180 degree thermoastat and the original Mopar 7 blade fan. The radiator is the original 26" 3 core. When you look into the radiator with the cap removed, on idle, it is better than a jacuzzi in there. Or when you look into the radiator, not running, it looks brand new.
The timing is correct. Will post, with temperature readings, after I make these recommended changes.
Re: Superbird Overheats [Re: Bayou_Bird] #1037038
07/23/11 10:51 AM
07/23/11 10:51 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Ask Dr. MoPAr for a pERcrIpTIon for some ZEREX G-05 and REDLINE water wetter.....your bird will feel better after a dose
Re: Superbird Overheats [Re: DAYCLONA] #1037039
07/23/11 10:54 AM
07/23/11 10:54 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
Mike, you have me convinced............ I'll go get some G05 to add to my distilled water and water wetter I already have...... My have to recharge the water wetter since I'll be draining some of the water inlew of the "G".......
Troy
Houston Mopar Connection Club
Re: Superbird Overheats [Re: Bayou_Bird] #1037040
07/23/11 02:33 PM
07/23/11 02:33 PM
California
mickm Offline
mickm  Offline
California
Hello Mike, I can't believe it but I drained the radiator and added plain hose water.
now drain it all and replace it with anti-freeze and distilled water.
i know some people argue this point, but every radiator guy i know insists on it, as well as all the engine builders i can think of. the minerals in tap water will eventually cause build-up and corrosion.
why take the chance?
Re: Superbird Overheats [Re: Bayou_Bird] #1037041
07/24/11 12:50 AM
07/24/11 12:50 AM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Ok, and that correct number is??!!
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Page 3 of 3 1 2 3
