How can the rear brake hose tee be repaired?
#1036238
07/19/11 11:36 PM
07/19/11 11:36 PM
Posts: 1,043 Motown, Mi
PAULS_340
Motown, Mi
I think the vent on top is leaking, can it be repaired? Any ideas, thanks.
Still looking for LM29H1B415501, '71 Demon 340
Re: How can the rear brake hose tee be repaired?
[Re: west]
#1036240
07/19/11 11:50 PM
07/19/11 11:50 PM
PAULS_340
Motown, Mi
I don't understand your first sentance but if the vent is leaking, how is it repaired?
[Re: PAULS_340]
#1036242
07/20/11 09:43 AM
07/20/11 09:43 AM
Posts: 75,088 A Banana Republic near you.
JohnRR
The vent is just a HOLLOW bolt , though it could be leaking past the threads , pull it out , clean it , put some teflon pipe thread sealer on the threads and put it back. I second checking to make sure it's not the brake lines leaking at the block.
Also is the rear overfilled perhaps ?
[Re: JohnRR]
#1036243
07/20/11 10:09 AM
07/20/11 10:09 AM
PAULS_340
Motown, Mi
I'll pull it and clean it. Not overfilled. Thanks
[Re: PAULS_340]
#1036245
07/20/11 09:47 PM
07/20/11 09:47 PM
Posts: 4,664 Newfoundland
mopar_man
Newfoundland
The vent cap is just that, a vent for the diff housing . It has nothing to do with the brake fluid / lines other than a holder for the the lines. I would check and see whats dripping down over the housing before repairing anything. Just rotating the vent cap sometimes is enough to make sure its venting properly. If its brake fluid , you may have a bad flare on the line, fitting could be cross-threaded or the brass block could have a hair line crack in it. Once you determine the type of liquid on the housing then start to repair .
