Re: Smoking Problem (HELP)
[Re: Dustin71]
#1036002
07/19/11 04:12 PM
07/19/11 04:12 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Hey Guys.... Need help with a Smoking Problem... My Duster W/440 is smoking out the mufflers when I'm in a traffic light or at a stop sign... Also when it's running at Idle... I have the Crankcase Evacuation System that Jegs sell's.... I've had this Kit on the car for a few Yrs now... Worked fine.... Never seen smoke from the exhuast before... But now there is smoke coming out the Exhuast ... Looks like light blue smoke (Oil) ..... I'm working on finding out what's going on with this smoke.... I know there's many reason on oil burning(Rings) (valve seals) (valve guides)ect... Need help on ruleing out the Evac System possibly pulling oil thru? Thanks for the help....
Take the hose off of the valve cover and put your hand over it... give it a few revs... is the hose stuck to your hand OR is it blowing back into the engine... take the hose off and go for a drive ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Cab_Burge]
#1036006
07/19/11 05:16 PM
07/19/11 05:16 PM
MR_P_BODY
I had an intake gasket that was letting oil get sucked into the intake ports, made smoke like that.
Come on guys... start with the easy stuff... if it isnt the evac then move on to the next easiest thing ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1036007
07/19/11 05:51 PM
07/19/11 05:51 PM
Posts: 197 New York
Dustin71
New York
Ok.... I Did the test that you said MR P_Body. And yes, there is one side of the Check Valve pushing Exhuast tru it... The other side is Sucking...the one pushing burned a hole in the hose....I'm almost out of work so I will drive it home and see if the Smoking stops.... And I'm hoping that it's as simple as a check valve... Even tho I was thinking about what Joshs68 said about the intake gasket sucking oil too... I did my own custom gasket since I home ported the heads and Intake. Will let you guys know later on tonight on the Driving Home and see if the smokes stops... Again I Thank you all for the help... ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Viol8r]
#1036008
07/19/11 05:54 PM
07/19/11 05:54 PM
Posts: 197 New York
Dustin71
New York
The checks on the evac system probably went bad and its pressuring the crankcase now.
![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Dustin71]
#1036009
07/19/11 05:58 PM
07/19/11 05:58 PM
MR_P_BODY
Understand its going to take some time to burn that oil out of the exhaust... see if it gets less.... hopefully thats the issue ![](/ubbthreads/images/graemlins/wave.gif)
