tourquiose engine paint? #103576
08/12/08 01:52 AM
08/12/08 01:52 AM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
any decent stuff in a spray can?
Re: tourquiose engine paint? [Re: 05dakota] #103577
08/12/08 02:14 AM
08/12/08 02:14 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Mopar Performance sells some, not perfect but close enough for most
Re: tourquiose engine paint? [Re: ScottSmith_Harms] #103578
08/12/08 02:06 PM
08/12/08 02:06 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
in my experience the MP paint is tin and doesn't bond well was hoping for another source.anyone use Bill Hirsch?
Re: tourquiose engine paint? [Re: 05dakota] #103579
08/12/08 06:13 PM
08/12/08 06:13 PM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
I've used the MP turquoise and it worked out great!
Re: tourquiose engine paint? [Re: cornucopia] #103580
08/12/08 10:19 PM
08/12/08 10:19 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
05 Dakota, try them again, it's from a new source now, HUGE difference from before
Re: tourquiose engine paint? [Re: ScottSmith_Harms] #103581
08/13/08 08:58 AM
08/13/08 08:58 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I just bought a few cans of MP turquoise engine paint and it went on very nicely.
Re: tourquiose engine paint? [Re: ScottSmith_Harms] #103582
08/13/08 08:59 AM
08/13/08 08:59 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
painted mine with Hirsh.
Re: tourquiose engine paint? [Re: ademon] #103583
08/13/08 09:11 AM
08/13/08 09:11 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
went on nice
Re: tourquiose engine paint? [Re: ademon] #103584
08/13/08 01:31 PM
08/13/08 01:31 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Roger Gibson's (Frank Badalson)
Re: tourquiose engine paint? [Re: A12] #103585
08/14/08 08:02 AM
08/14/08 08:02 AM
1.5 hours SE of Pittsburg, Pa
geno440 Offline
geno440  Offline
My problem with the MP paint is that it doesn't stay on. Usually in less than a year it starts comming off and rust shows through. It looks good going on and nice right after you paint it.
Maybe i'm doing something wrong. I sandblasted my intake clean and then applied about 2 or 3 coats, allowing for sticky dry in between.
I'm not going to use it any more.
Love them 68 MOPARS! GTS 340 auto, Charger R/T 440 4-speed, Superbee 383 auto, GTX 440 auto, D100 (new front frame 5.7 hemi - in process), Formula S 340 4-Speed A/C (it's green), 383 auto Roadrunner (maybe a hemi - waiting) and a 68 W200 Power Wagon. Drivers: 07 Cummins and 14 Ecodiesel 4x4.
Re: tourquiose engine paint? [Re: geno440] #103586
08/15/08 08:51 AM
08/15/08 08:51 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Hopefully it will hold up:
Re: tourquiose engine paint? [Re: geno440] #103587
08/15/08 08:56 AM
08/15/08 08:56 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I always spray my parts down with brake parts cleaner to remove any impurities. Here are the valve covers just prior to paint:
Re: tourquiose engine paint? [Re: 69Cuda340S] #103588
08/15/08 02:35 PM
08/15/08 02:35 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I've even taken a propane torch to all metal parts and "burned" or evaporated the fluids, grease, liquids off or out of the pores, cracks, corners, etc.,............wait a while before you do this if you just used lacquer thinner, or contact cleaner...."don't ask me how I know"
Re: tourquiose engine paint? [Re: A12] #103589
08/16/08 08:27 AM
08/16/08 08:27 AM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
I like Bill Hirsh products.
Re: tourquiose engine paint? [Re: Michael] #103590
08/16/08 03:33 PM
08/16/08 03:33 PM
Gibsons BC Canada
dalei989 Offline
dalei989  Offline
Gibsons BC Canada
I painted my intake with MP torquise and went on fine, still burn't off at the crossover. I have five cans if anyone wants them, we just have to figure how to ship as cannot mail them. I order a can from my local chrysler dealer and when they order came in it was a case of 6 cans. I am only keeping two so three cans are yours free if we can find a shipping source. thanks
1971 340 Swinger Canadian Car
1972 Dodge Dart Prostreet 440
2013 Dodge Ram 1500
Re: tourquiose engine paint? [Re: 05dakota] #103591
08/16/08 07:22 PM
08/16/08 07:22 PM
Phoenix, AZ
MCTPhoenix Offline
MCTPhoenix  Offline
Phoenix, AZ
Ive found that it's not the paint (either rattle can or spray gunned) as much as the prep. I've been epoxy priming bare metal, both cast iron heads and block and sheetmetal valve covers etc prior to spraying on color for years. An inexpensive alternative is to use self-etch primer ina spray can. Any body supply store will have it. Don't go overboard.. just dust it on light to achive hiding then go over with your engine color. My oldest was done in '92... no peel or flaking.
Re: tourquiose engine paint? [Re: 05dakota] #103592
08/16/08 09:24 PM
08/16/08 09:24 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
Here`s my 71 vintage 440 which is dressed as a 68 vintage engine that is going into my Charger. It was sprayed with the Mopar spray bomb paint . I`ve always had good luck with it.
