69 273 timing cover same as 74 360 truck? #1035752
07/19/11 03:41 AM
07/19/11 03:41 AM
Ca
76440 Offline OP
76440  Offline OP
Ca
Timing cover broke on the 1969 273. Will the timing cover off the 74 truck 360 work? Thanks
Re: 69 273 timing cover same as 74 360 truck? [Re: 76440] #1035753
07/19/11 07:36 AM
07/19/11 07:36 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
it should fit but I believe the timing marks wont be right...
I am truckless..
Re: 69 273 timing cover same as 74 360 truck? [Re: 76440] #1035754
07/19/11 03:23 PM
07/19/11 03:23 PM
BA, OK
O
orangedustya Offline
O
BA, OK
Yes it will work and the 69 should have a timing tab that is bolted on with the two bottom bolts of the water pump. Just transfer this over when you change the cover. At least thats what I did on my 68.
