Re: Hotchkis Dodge Challenger Suspension
[Re: autoxcuda]
#1034858
07/22/11 02:09 PM
07/22/11 02:09 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
What are the specs of the rear rims she has on there now?
I'm not 100% sure. I'm helping her out from here at work. I think she has 15x7's with 245/60R15's up front. The shop had to put those on the rear so the car would roll. He had an extra set of rims/tires he installed on the front. The car is at the alignment shop now. I believe she has 15x8's with 275/60R/15's out back that apparently are rubbing the wheel lip opening area now. Not sure what the backspacing is..
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#1034859
07/22/11 02:14 PM
07/22/11 02:14 PM
Posts: 27,480 So Cal
autoxcuda
So Cal
Are they Rallyes or magnum 500's?
Off the shelf 15x7 repro Magnum and Rallyes are 4.25" backspace. The 15x8's are 4.5 backspacing.
[Re: 71STROKERFISH]
#1034861
07/23/11 12:30 PM
07/23/11 12:30 PM
Posts: 450 DFW
68RRFlyer
DFW
Has anyone installed/seen the contoured subframe connecors that actually look like frame rails. I have seen these and think they would be a more stock look...maybe even more effective too...
I'm doing an entire Hotchkis suspension setup on a 68 Charger and have installed XV's laser cut frome connectors, front radiator support, and upper firewall to inner fender connectors. As shown in that picture with the Challenger on one jack stand, this setup (the welded one) really looks like a factory installation. Plans on the car are a 6.1L, 5spd, Dana out back. The suspension system is 100%A top notch!!! ![](/ubbthreads/images/graemlins/thumbs.gif)
Cheers ![](/ubbthreads/images/graemlins/beer.gif)
[Re: 68RRFlyer]
#1034862
07/23/11 01:42 PM
07/23/11 01:42 PM
hemi68charger
Houston, Tx
Cheers
Well, look at you Dave.......... ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: hemi68charger]
#1034863
07/23/11 01:46 PM
07/23/11 01:46 PM
autoxcuda
So Cal
... I believe she has 15x8's with 275/60R/15's out back that apparently are rubbing the wheel lip opening area now. Not sure what the backspacing is..
Did you figure out the rims specs and backspacing she has on those rear tires?
[Re: autoxcuda]
#1034864
07/25/11 08:49 AM
07/25/11 08:49 AM
hemi68charger
Houston, Tx
Hey Steve.. Nope,,, I haven't spoken to her this weekend. She brough two of her 15x7 Ralleys and put them on to get the car home. Another friend made a suggestion, putting a '68-'70 B-body rear 8.75 housing w/axles in the car. It's narrower and will give her more room outboard so she can keep the wheels she wants. I believe she'll still have inboard clearance. Sounds in theory like a good idea..
[Re: 68RRFlyer]
#1034865
07/27/11 01:45 PM
07/27/11 01:45 PM
Posts: 203 Sante Fe Springs, CA
Hotchkis
Cheers
68RRFlyer – Looks like you have a great project going there! Thanks for choosing Hotchkis suspension products for your build! Keep us posted on your progress.
[Re: hemi68charger]
#1034866
07/27/11 01:58 PM
07/27/11 01:58 PM
Hotchkis
Troy - if you or your friend with the Challenger have the full TVS system, you can join the H-Team. If you drive your cars rather than just use them for car show duty, and have a TVS you are eligible. Members get a shirt, decal, and access to members-only driving events.
Here's an H-Team Track day earlier this year. http://youtu.be/VyrRfcr4kIc
