which radiator hoses ? on my third set already #1034492
07/17/11 09:49 PM
07/17/11 09:49 PM
SE Mi
U
use2teech Offline OP
U
SE Mi
Hope someone can help out.....I have read through the many posts regarding what radiator hoses to use and keep coming up empty (wrong hoses). I have a 65 coronet, original 383 car. It came to me (in many pieces) with a 22 inch radiator and I am putting in a 440, 1977 model year. My upper hose is located top PASSENGER SIDE of the radiator and lower is on the far left (drivers side) of the radiator - which makes for a long travel to get to the passenger side of the engine. Anyone know for sure what hoses, where from, etc ? As always, appreciate all the help from you guys !
Re: which radiator hoses ? on my third set already [Re: use2teech] #1034493
07/17/11 10:00 PM
07/17/11 10:00 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
[Quote] " I have a 65 coronet, original 383 car...with a 440, 1977 model year. My upper hose is located top center of the radiator and lower is on the far left (drivers side) of the radiator -which makes for a long travel to get to the passenger side of the engine."
You might wanna get a different pump housing. I think the early 60's were different than the later 70's motors.
Re: which radiator hoses ? on my third set already [Re: bboogieart] #1034494
07/17/11 11:37 PM
07/17/11 11:37 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
A radiator shop could relocate your outlet pretty easily for you.
It's Swifty! Swifty, you toad sucker!
Re: which radiator hoses ? on my third set already [Re: zrxkawboy] #1034495
07/18/11 12:11 AM
07/18/11 12:11 AM
scratchnfotraction Offline
change rad
move lower outlet on rad
change WP housing to a car unit
later cars/trucks use the pass side lower hose WP housing
use 2 hoses and a nipple to cross over to hook it up
Re: which radiator hoses ? on my third set already [Re: scratchnfotraction] #1034496
07/18/11 10:27 AM
07/18/11 10:27 AM
gtx69 Offline
super gas
gtx69  Offline
super gas
Change water pump housing to pre-72
Re: which radiator hoses ? on my third set already [Re: gtx69] #1034497
07/18/11 11:21 AM
07/18/11 11:21 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
This is the much easier and cheaper way to go.
You should have no problem getting the earlier pump housing. Where are you located? I'll send you one for the cost of shipping .
Re: which radiator hoses ? on my third set already [Re: JohnRR] #1034498
07/18/11 11:54 AM
07/18/11 11:54 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Do you still have the old 383? If so there you go. If not John RR has your best solution.
I have mechanical Aptitude.
I can screw up anything.
Re: which radiator hoses ? on my third set already [Re: bboogieart] #1034499
07/18/11 12:43 PM
07/18/11 12:43 PM
SE Mi
U
U
SE Mi
Thanks.....don't know if it changes anything but I screwed up....the upper outlet on the radiator is actualy on the passenger side of the radiator....I originallty wrote it was in the center.
Re: which radiator hoses ? on my third set already [Re: use2teech] #1034500
07/18/11 12:50 PM
07/18/11 12:50 PM
U.S.S.A.
U.S.S.A.
That doesn't matter , your problem is the lower outlet on the pass side of the engine . get the correct waterpump and all you need to do is get hoses for a 65 coronet .
Re: which radiator hoses ? on my third set already [Re: JohnRR] #1034501
07/18/11 01:19 PM
07/18/11 01:19 PM
SE Mi
U
U
SE Mi
John
Thanks and let me know how to pay you....I am interested in getting the older style housing.
Re: which radiator hoses ? on my third set already [Re: use2teech] #1034502
07/18/11 02:48 PM
07/18/11 02:48 PM
U.S.S.A.
U.S.S.A.
Do you have the original 383 from this car ?
Re: which radiator hoses ? on my third set already [Re: JohnRR] #1034503
07/18/11 03:35 PM
07/18/11 03:35 PM
SE Mi
U
U
SE Mi
no...came in pieces, no motor.
Re: which radiator hoses ? on my third set already [Re: use2teech] #1034504
07/18/11 04:35 PM
07/18/11 04:35 PM
U.S.S.A.
U.S.S.A.
Then to answer your other question you'll need to get a set of the earlier valve covers also .
Re: which radiator hoses ? on my third set already [Re: JohnRR] #1034505
07/18/11 04:49 PM
07/18/11 04:49 PM
SE Mi
U
U
SE Mi
any reason to not stay with the later model covers and buy breathers for later model covers ?
Re: which radiator hoses ? on my third set already [Re: use2teech] #1034506
07/18/11 04:51 PM
07/18/11 04:51 PM
U.S.S.A.
U.S.S.A.
As long as you can find what you need there is no reason not to switch I guess . from your PM I have no idea what you need , it didn't make sense ?
