How sharp a mopar nut are you, name these seats.... #1034347
07/17/11 06:35 PM
07/17/11 06:35 PM
USA
ramairthree Offline OP
USA
My 74 RR needed a windshield, and used the inexpensive but not 100% correct modern replacement.
My choice was no interior, or a free 73 Satellite interior
Free is good.
(I cut the rear lower door panels to accomodate the seat belt retractors, and plan to stick an emblem over the uneeded rear window crank holes, and some emblem to replace the r/w/b front door panel emblems- call me cheap, but this car was for sale for months and about to get parted out or crushed, I saved it to make a budget driver, and you all know what a nice used or new repro RR interior costs)
I was lucky that I got a nice, usable center console and complete shifter, and even found the lock core under the ratty carpet. The rear ashtray was even jam packed with butts. The days of cars with two to four ashtrays stock from the factory is long over.
However, someone with a bench seat column shift had already snagged the bucket seats.
I THINK I know what these buckets came from,
but test your made ID skills...
If I am correct, the frame and foam is the same as for a RR, just different upholstery covers.
Headliner and dash have seen better days as well
ps- minus some of the grip, is what I have the tuff wheel?
Re: How sharp a mopar nut are you, name these seats.... [Re: ramairthree] #1034348
07/17/11 06:42 PM
07/17/11 06:42 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i can't name those seat (Cordorba maybe?) but i truly admire your 'ghetto' spirit!
Re: How sharp a mopar nut are you, name these seats.... [Re: mikemee1331] #1034349
07/17/11 07:12 PM
07/17/11 07:12 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
They look like 70/71 E-body seats to me (with non original upholstery)
Re: How sharp a mopar nut are you, name these seats.... [Re: ScottSmith_Harms] #1034350
07/17/11 07:18 PM
07/17/11 07:18 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
70/71s uses diff back panel and hinge covers with a larger release button.
Re: How sharp a mopar nut are you, name these seats.... [Re: NachoRT74] #1034351
07/17/11 07:22 PM
07/17/11 07:22 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm aware of that Nacho (and actually there's 2 styles of 70-71 seat backs, one with a hinge cover built in, one with a sepperate pot metal hinge cover...1970 and early 71) but his pics aren't clear/close enough for me to see exactly what he's got there.
Re: How sharp a mopar nut are you, name these seats.... [Re: ScottSmith_Harms] #1034352
07/17/11 07:33 PM
07/17/11 07:33 PM
St Louis, Mo USA
Wagonmaster'79 Offline
St Louis, Mo USA
Cordoba
My reading of history convinces me that most bad government results from too much government - Thomas Jefferson.
Re: How sharp a mopar nut are you, name these seats.... [Re: Wagonmaster'79] #1034353
07/17/11 08:11 PM
07/17/11 08:11 PM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Cordoba, bagged a set years ago
Re: How sharp a mopar nut are you, name these seats.... [Re: Sixgun] #1034354
07/17/11 08:24 PM
07/17/11 08:24 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
They look like the right seats to me with the inserts replaced to me
Re: How sharp a mopar nut are you, name these seats.... [Re: scatpacktom] #1034355
07/17/11 08:32 PM
07/17/11 08:32 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I think Cordoba is the correct (or close) answer ...... here is a pair from a '77 Charger SE.
Re: How sharp a mopar nut are you, name these seats.... [Re: scatpacktom] #1034356
07/17/11 08:32 PM
07/17/11 08:32 PM
USA
USA
better pics to show release, aduster, and back
Re: How sharp a mopar nut are you, name these seats.... [Re: ramairthree] #1034357
07/17/11 09:26 PM
07/17/11 09:26 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
do i get a prize?
Re: How sharp a mopar nut are you, name these seats.... [Re: ramairthree] #1034358
07/17/11 10:39 PM
07/17/11 10:39 PM
SF Bay Area, CA
charger440sixpak Offline
SF Bay Area, CA
That's a big 10-4...
Re: How sharp a mopar nut are you, name these seats.... [Re: charger440sixpak] #1034359
07/17/11 11:59 PM
07/17/11 11:59 PM
USA
USA
no prizes.
thanks for the tip on the wheel,
any good material out there to repair?
I THOUGHT they were Cordoba seats from looking around and asking around, but am not sure if they are acutal RR seats that have been re-covered for a pimpin' blue ride before getting sprayed black at some point in the past.
the pattern looks Cordoba-ish, but the Cordoba seats I can get my eyes on have more extensive hinges/covers on the sides.
Re: How sharp a mopar nut are you, name these seats.... [Re: ramairthree] #1034360
07/18/11 12:05 AM
07/18/11 12:05 AM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Ya those are the seats Ricardo ripped gas on.
Re: How sharp a mopar nut are you, name these seats.... [Re: Y3 70 BEE] #1034361
07/18/11 12:32 AM
07/18/11 12:32 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
I'm glad you saved the car. Too many of these things are disappearing. Even a driver quality one like yours is good to see. Good luck with the project.
Re: How sharp a mopar nut are you, name these seats.... [Re: MoparMarq] #1034362
07/18/11 07:42 PM
07/18/11 07:42 PM
USA
USA
Thank you, I really appreciate that.
It may not be pretty, and obviously not getting the royal treatment,
but it is not getting crushed or parted out like it was going to after being a stalled project for years with the original owner's nephew, then for sale with no bites for months with the next owner.
Re: How sharp a mopar nut are you, name these seats.... [Re: Y3 70 BEE] #1034363
07/18/11 08:56 PM
07/18/11 08:56 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
buuuhuwhahahaha
