Oil Pressure #1033906
07/17/11 01:08 AM
07/17/11 01:08 AM
Missouri
Clements Offline OP
Clements  Offline OP
Missouri
My Mechanical Oil pressure gauge on my 500 cid B Stroker reacts like a tach. Have about 1 hr on the motor with no knocking etc. Never drops below 20 but races to 65 and then right back down fast. Melling high volume. Thx ahead
Re: Oil Pressure [Re: Clements] #1033907
07/17/11 01:36 AM
07/17/11 01:36 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
And your Q is what ? .... sounds OK(on the surface) to me. What weight oil? ... what is your oil temp?
Re: Oil Pressure [Re: dOoC] #1033908
07/17/11 01:41 AM
07/17/11 01:41 AM
Missouri
Clements Offline OP
Clements  Offline OP
Missouri
30 weight. Just have never seen a needle react so fast. Nothing gradual about it. Does it from a cold start all the way up to 195 engine temp.
Re: Oil Pressure [Re: Clements] #1033909
07/17/11 01:47 AM
07/17/11 01:47 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Straight 30 ? ... do you know how the motor has been clearanced?
Re: Oil Pressure [Re: dOoC] #1033910
07/17/11 01:50 AM
07/17/11 01:50 AM
Missouri
Clements Offline OP
Clements  Offline OP
Missouri
10w30 Not sure on clearance. Taking it out on the road for the first time tomorrow. Would air in line do this?
Re: Oil Pressure [Re: Clements] #1033911
07/17/11 01:57 AM
07/17/11 01:57 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
10-30 is not a very heavy oil. Any air in-the-lines would be long-gone after 1 hour running time.
Re: Oil Pressure [Re: dOoC] #1033912
07/17/11 02:04 AM
07/17/11 02:04 AM
Missouri
Clements Offline OP
Clements  Offline OP
Missouri
Suggests on oil?
Re: Oil Pressure [Re: Clements] #1033913
07/17/11 02:06 AM
07/17/11 02:06 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
What cam is in it ?
Re: Oil Pressure [Re: dOoC] #1033914
07/17/11 02:16 AM
07/17/11 02:16 AM
Missouri
Clements Offline OP
Clements  Offline OP
Missouri
Comp Cam Xtreme Energy Hi-Lift .564"
Re: Oil Pressure [Re: Clements] #1033915
07/17/11 02:22 AM
07/17/11 02:22 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
roller ?
Re: Oil Pressure [Re: dOoC] #1033916
07/17/11 02:27 AM
07/17/11 02:27 AM
Missouri
Clements Offline OP
Clements  Offline OP
Missouri
No
Re: Oil Pressure [Re: Clements] #1033917
07/17/11 02:29 AM
07/17/11 02:29 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
I would find some HIGH ZINC oil ....like Valvoline or Brad PITT !
Re: Oil Pressure [Re: dOoC] #1033918
07/17/11 02:32 AM
07/17/11 02:32 AM
Missouri
Clements Offline OP
Clements  Offline OP
Missouri
Thx
