Where to find late 70s/early 80s style speedo gear?
#1032291
07/14/11 01:08 AM
07/14/11 01:08 AM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Looking for somewhere that sells the speedo gears for the late 70s-early 80s style speedo housing. I need a 35 tooth gear for my 78 Fury, that uses the push-in cable, not the earlier screw in style. Anybody know of where I can find one?
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
Re: Where to find late 70s/early 80s style speedo gear?
[Re: mopars4ever]
#1032296
07/14/11 12:28 PM
07/14/11 12:28 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
The dealer said they are discontinued. I do have everything need to swap to the older style speedo adapter, but with the A500, it barely has enough room for the stock push in style cable. The cable is right up against the back of the crossmember. It's quite a tight fit. I guess I could modify the crossmember so the large nut on the older cable will clear. I was just trying to avoid that though.
