Where to find late 70s/early 80s style speedo gear? #1032291
07/14/11 01:08 AM
07/14/11 01:08 AM
Glendale, AZ
69L78Nova Offline OP
Banned. Forever.
Banned. Forever.
Glendale, AZ
Looking for somewhere that sells the speedo gears for the late 70s-early 80s style speedo housing. I need a 35 tooth gear for my 78 Fury, that uses the push-in cable, not the earlier screw in style. Anybody know of where I can find one?
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Where to find late 70s/early 80s style speedo gear? [Re: 69L78Nova] #1032292
07/14/11 01:33 AM
07/14/11 01:33 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
A and a pic so people can see whatcha need, though this gear is 23 teeth.
Re: Where to find late 70s/early 80s style speedo gear? [Re: In_The_Pink] #1032293
07/14/11 03:37 AM
07/14/11 03:37 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Have you tried the dealership?
Re: Where to find late 70s/early 80s style speedo gear? [Re: None2Slow] #1032294
07/14/11 12:04 PM
07/14/11 12:04 PM
Salinas, California
1970Cuda Offline
super street
1970Cuda  Offline
super street
Salinas, California
Hit up your local transmission rebuilder.
Re: Where to find late 70s/early 80s style speedo gear? [Re: 1970Cuda] #1032295
07/14/11 12:20 PM
07/14/11 12:20 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Just a thought. I changed my 77 volare back to the older style. I replaced the cable and housing adapter. I used a 76 cable which had the correct connector for the speedometer head and the early type screw on connector on the trans end. I don`t know if that will work for you but it is worth checking into since the earlier style gears are more available.
Re: Where to find late 70s/early 80s style speedo gear? [Re: mopars4ever] #1032296
07/14/11 12:28 PM
07/14/11 12:28 PM
Glendale, AZ
Banned. Forever.
Banned. Forever.
Glendale, AZ
The dealer said they are discontinued. I do have everything need to swap to the older style speedo adapter, but with the A500, it barely has enough room for the stock push in style cable. The cable is right up against the back of the crossmember. It's quite a tight fit. I guess I could modify the crossmember so the large nut on the older cable will clear. I was just trying to avoid that though.
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: Where to find late 70s/early 80s style speedo gear? [Re: 69L78Nova] #1032297
07/14/11 01:03 PM
07/14/11 01:03 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried Ebay?
Re: Where to find late 70s/early 80s style speedo gear? [Re: stumpy] #1032298
07/14/11 01:27 PM
07/14/11 01:27 PM
North East Missouri
E
express Offline
express  Offline
E
North East Missouri
Post a wanted ad here on Moparts. I bought one from a guy here who sells on ebay & had hundreds of them. Very happy with him.
cny25421@centurytel.net 70 Duster Turbo Charged 79 Lil Red Express Bonded Locksmith
Re: Where to find late 70s/early 80s style speedo gear? [Re: 69L78Nova] #1032299
07/14/11 01:33 PM
07/14/11 01:33 PM
top-o-the world
RAMIT Offline
RAMIT  Offline
top-o-the world
yearone?
Re: Where to find late 70s/early 80s style speedo gear? [Re: RAMIT] #1032300
07/14/11 03:56 PM
07/14/11 03:56 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Re: Where to find late 70s/early 80s style speedo gear? [Re: nomore65BelvJim] #1032301
07/14/11 04:55 PM
07/14/11 04:55 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Could you use a 90* speedo cable adapter between the cable and older style pinion housing?
