AVS accelerator pumps #1031993
07/13/11 03:31 PM
07/13/11 03:31 PM
Columbus, OH
Spanky Offline OP
Spanky  Offline OP
Columbus, OH
Are the accelerator pumps for the new Thunder Series AVS the same as the old mopar AVS's? I've got a 4401S if it makes any difference.
Re: AVS accelerator pumps [Re: Spanky] #1031994
07/13/11 03:45 PM
07/13/11 03:45 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I'd like to know if they're the same as an AFB too.
- Stu Harmon
Re: AVS accelerator pumps [Re: feets] #1031995
07/13/11 03:52 PM
07/13/11 03:52 PM
Cincinnati, Ohio
chargincharles Offline
Cincinnati, Ohio
On the old Carter AVS's and AFB's they were. On the Eddies- not sure.
This much I DO know- the new Eddies use some plastic/fiber/rubber assembly for the accel pump. The old carters were Brass/Steel with a Leather seal. I wouldn't trust the new ones for ANYTHING! I've not tried the new ones in an old carb, but I just don't like the design of the new one's at all. Looks WAYYYYYY too flimsy to get the job done. Might be a contributing factor to the new Eddies getting such a bad rap.
Anyway,
I'd buy a rebuild kit for an old one just to get the old-style accel pump.
Try Mancini Racing for a rebuild kit for you old AVS. They normally stock them, and they are the correct kit.
Enjoy!
CC.
Re: AVS accelerator pumps [Re: feets] #1031996
07/13/11 03:55 PM
07/13/11 03:55 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The original AFB uses a smaller diameter pump than the AVS.
Re: AVS accelerator pumps [Re: 62maxwgn] #1031997
07/13/11 04:03 PM
07/13/11 04:03 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I've got spare plungers for the Eddy carbs. I'll have to measure the AVS to see if it's the same size bore.
The AVS accelerator pump does not work. The passages are clear (aerosol test) and the plunger seems pliable. I think sitting for 12 years didn't do the carb any favors.
- Stu Harmon
Re: AVS accelerator pumps [Re: feets] #1031998
07/13/11 06:46 PM
07/13/11 06:46 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
What about the ball check valve in the driver side bottom of the bowl and the one in the bottom of the pump ?
Re: AVS accelerator pumps [Re: 62maxwgn] #1031999
07/13/11 06:53 PM
07/13/11 06:53 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Edelbrock used to sell plungers separately. I bought a couple for some 500's I used to have.
Re: AVS accelerator pumps [Re: slantzilla] #1032000
07/13/11 08:01 PM
07/13/11 08:01 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: AVS accelerator pumps [Re: Spanky] #1032001
07/13/11 11:13 PM
07/13/11 11:13 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
So you need the pump for the 4401s? If so just buy the kit, they are available, usually needs to be ordered, from any good parts store.
Re: AVS accelerator pumps [Re: rrunner] #1032002
07/13/11 11:59 PM
07/13/11 11:59 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I just put a kit in my old AVS as it had a bad off the line bog due to a very late pump shot that could not be adjusted out. The kit had the proper leather pump, but no matter what, I cannot get the pump shot to come in immediately. I have overhauled over 100 carbs in my life and never had a problem like this. I am beginning to think that the ethanol is affecting the pumps ability to seal well. I am going to try the edelbrock pump as I have had no problems with them working in later AFB's.
Re: AVS accelerator pumps [Re: Lee446] #1032003
07/14/11 12:24 AM
07/14/11 12:24 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I went through the same thing in my AVS. Sometimes you just don't get the shot. Really no reason for it. Worked fine most of the time.
I want my fair share
Re: AVS accelerator pumps [Re: SomeCarGuy] #1032004
07/14/11 01:16 AM
07/14/11 01:16 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Get an Edelbrock pump....1470 I think.I used one in my GTX...seems a lot better on the shot.
Re: AVS accelerator pumps [Re: superwrench] #1032005
07/14/11 10:19 AM
07/14/11 10:19 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
There are three different pumps,one for the AVS and two for the AFB.AVS is larger in diameter,AFB uses two different length pumps,AVS on right,AFB's on left.The AFB pumps have a check valve in the bottom of the pump,the AVS does not.If you have the correct pump,the pump length adjustment is correct,the connecting link is not installed backwards,the check valve in the driver side bowl to pump well is good,correct fuel level and the needle under the discharge nozzle is in place you should have no problem regardless of what pump you use if it is in good condition.I have been playing with these thing for 40 + years and can honestly say I have never had a pump problem if all the above are correct.I have went as far as soaking dried up leather pumps in oil and reusing them with no problems.
Re: AVS accelerator pumps [Re: 62maxwgn] #1032006
07/14/11 10:39 AM
07/14/11 10:39 AM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
I know the Edelbrock rebuild kit(#1477) does NOT come with a new pump. It has to be purchased separately. O'Reilly auto parts has them in stock for $15. The new pumps are supposed to be ethanol compatible. I know it is different than the old edelbrock pumps I took out of 4 carbs. Just throwing this out for people wondering.
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: AVS accelerator pumps [Re: 62maxwgn] #1032007
07/14/11 10:42 AM
07/14/11 10:42 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: AVS accelerator pumps [Re: 62maxwgn] #1032008
07/14/11 11:32 AM
07/14/11 11:32 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I put the Edelbrock pump into my AVS on my '69 GTX (from Bee1971 and superwrench's info in the linked thread ) but had to shorten it and drill a new hole for the wire clip. The Edelbrock pump was as long or tall as the one in the center in Bill's photo and the original AVS was shorter like the one on the right in the photo. Took just a little modification but it works......about 20 bucks from Summit or get the local Advance Auto Parts to match Summit's price, Advance's price was about $10 more.
MikeR
Re: AVS accelerator pumps [Re: A12] #1032009
07/14/11 11:58 AM
07/14/11 11:58 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Edelbrock and original AVS
Re: AVS accelerator pumps [Re: A12] #1032010
07/14/11 12:05 PM
07/14/11 12:05 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Never thought about seeing if I could transfer the seal/piston from the Edelbrock to the original AVS pump
MikeR
Re: AVS accelerator pumps [Re: A12] #1032011
07/14/11 12:07 PM
07/14/11 12:07 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Getting on the ride.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: AVS accelerator pumps [Re: A12] #1032012
07/14/11 12:09 PM
07/14/11 12:09 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Or remove that black piece on the bottom of the Edelbrock pump.....don't know what it's for or if it's needed to work????
