Weight loss questions... #1031521
07/13/11 01:42 AM
07/13/11 01:42 AM
Red Deer, Alberta
bill_greenwood Offline OP
Red Deer, Alberta
Getting back to the track this year is looking more and more problematic due to circumstances beyond my immediate control. But, I may as well make progress where I can. I'd like to shed some weight on my Dart, so I'm going to start gathering up fiberglass for starters. How many pounds can we expect to shed by going with fiberglass hood and front fenders on a 69 Dart? I'd also like to lighten the doors without losing the stock window cranks and glass. Is there any weight to be found there? The car currently weighs 2930 without me in it, and I'd like to get it to 2700 or less. What else will I have to look at to get there?
Re: Weight loss questions... [Re: bill_greenwood] #1031522
07/13/11 02:23 AM
07/13/11 02:23 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Man, we`re on the same page here as I`m lookin to do the same but 2700lbs, that seems awfully light w/out some major mods. My big block 72 dart is about 3150 w/me and that`s w/gutted doors and only drivers window rolls up and down, glass hood and ft. bumper and brackets and no back seat. I`m watchin this one closely.........
Re: Weight loss questions... [Re: Thumperdart] #1031523
07/13/11 04:08 AM
07/13/11 04:08 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Alloy water pump, alloy m/c, i took around 15 lbs out of the K member, good savings on the bumper brackets, i used glass ones on the front and cut the rears in half and holesawed them out. Anti roll bar took around 12 lbs off.
Your car is lighter than mine though.
To get 2700, i think you would need glass doors and alloy or glass dash, pin on glass trunk lid etc.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Weight loss questions... [Re: deaks] #1031524
07/13/11 08:22 AM
07/13/11 08:22 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
if you have a big block, use a alumn block, the rear deck is heavy, i went with the glass, remove the outer front bumper brackets or go with glass bumpers. aluumn radiator if you dont already have one. just some examples.
Re: Weight loss questions... [Re: bill_greenwood] #1031525
07/13/11 09:06 AM
07/13/11 09:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Make sure the under coating is gone, insulating mat
under the carpet, lose the stock wiring harness and
wire just what you need, dump the front brakes for
light weight racing brakes... cut off any extra length
on every bolt...light weight racing wheels and tires...
dump the T-bars for coil over shocks... thats a few things
Re: Weight loss questions... [Re: MR_P_BODY] #1031526
07/13/11 12:13 PM
07/13/11 12:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
But even with everything mentioned...........2700lbs. sounds like tube chassis territory or at least a back half.......... I`ve have everything mentioned except the deck lid and coil overs.
Re: Weight loss questions... [Re: Thumperdart] #1031527
07/13/11 01:49 PM
07/13/11 01:49 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
My tube chassis Duster(MS) weighed 2550. R/P steering, liteweight brakes, glass hood/decklid, plastic cell, ect. I really doubt one could get a stock type chassis car 2700 pounds.
Re: Weight loss questions... [Re: bill_greenwood] #1031528
07/13/11 02:01 PM
07/13/11 02:01 PM
Ohio
aquamist60 Offline
aquamist60  Offline
Ohio
A few years ago we took the Duster to the scales. No engine, tranny, seats, carpet, battery. Had Cragars & street tires and a 12 pt. cage, complete wiring front to back, fiberglass hood, stock bumpers, glass, frame tied, narrowed 8 3/4 rear, S/S springs. Don't remember what else was out or in. Shocked us when it weighed 2030 lbs. I expected it'd weigh more than that.
Re: Weight loss questions... [Re: aquamist60] #1031529
07/13/11 02:14 PM
07/13/11 02:14 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I tried to make swiss cheese out of my doors. After I was done hole-sawing the driver's door, I weighed all the "plugs" I cut out. A whold whopping 1 lb. Yes one pound. I didn't even open the passenger's side door to start cutting. I never weighed mine, but I have glass fenders, hood, and decklid. Plus aluminum inner fenders on the front. Got rid of all the under coating. No back seat. I should take it to the scales just for fun.
Re: Weight loss questions... [Re: 70HemiGTX] #1031530
07/13/11 03:29 PM
07/13/11 03:29 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
very little money involved here but it took time. lost alot of weight. i dont know if the car is going to stear right though either
Re: Weight loss questions... [Re: 70HemiGTX] #1031531
07/13/11 03:33 PM
07/13/11 03:33 PM
Almost Heaven
B_Body_Bob Offline
Master of nothing
B_Body_Bob  Offline
Master of nothing
Almost Heaven
I pulled the dash frame out of my car. It had been trimmed up by Vanke's shop back in the 70s when the car was prepped. Compared to a stock one, there less than 2 lbs difference. Doesn't seem to be worth the effort to me, but all you have to do is lose that amount of weight in 50 places, and you've saved a 100 lbs.
Everybody makes fun of a hillbilly until they need something fixed
Re: Weight loss questions... [Re: deaks] #1031532
07/13/11 07:37 PM
07/13/11 07:37 PM
Aubrey, Texas
O
oldtimer5151 Offline
O
Aubrey, Texas
Could you send pictures of the lightened k frame?
Re: Weight loss questions... [Re: oldtimer5151] #1031533
07/13/11 08:26 PM
07/13/11 08:26 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Re: Weight loss questions... [Re: BobR] #1031534
07/13/11 10:24 PM
07/13/11 10:24 PM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
I havent weighed my 68 notchback since last weight saveings but I am sure it is real close to 2700 it was 2785 without me before going with light weight brakes on all corners and front runners, and I still have steel doors,fenders and decklid
Re: Weight loss questions... [Re: sixpackgut] #1031535
07/13/11 11:35 PM
07/13/11 11:35 PM
ill
dennismopar73 Offline
ill
my front is kinda close to youres , can i get close up pick of youre tie rods and mounting of rack please
my car around 2500 # w/o driver
Re: Weight loss questions... [Re: bill_greenwood] #1031536
07/14/11 08:57 AM
07/14/11 08:57 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My 69 Dart with a aluminum headed small block, 727, aluminum radiator, Dana, bolt on 6 pack glass hood and glass front bumper, full interior with Kirkey seats, heater, wipers, factory glass and 3" exhaust to the rear end weighs 3085 without me. I lightened the front bumper brackets and saved almost 5.5#, the glass front bumper saved 20# and the bolt on glass six pack was 31# lighter than the stock flat hood. The Strange front brakes were 50# lighter than the 73 disk setup I had on it. These items alone are almost 100# with out really much work.
I don't think glass fenders would save enough over the stock ones to justify the cost.
Re: Weight loss questions... [Re: justinp61] #1031537
07/14/11 06:49 PM
07/14/11 06:49 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
not sure what ur cash situation is,but i will tell u this,if u put a alterkation rms k frame,with the disc brakes+the rack i see 100lbs out,and just 1 of the best investments u can make to an older car!
Re: Weight loss questions... [Re: dennismopar73] #1031538
07/15/11 12:25 AM
07/15/11 12:25 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
i would have to take some pics tomorrow. now that the car is sitting at ride height, i see i am going to have to make some changes for bump steer or whatever. i really dont think you should listen to me on this subject though. i just try things just to do it
Re: Weight loss questions... [Re: sixpackgut] #1031539
07/15/11 03:01 AM
07/15/11 03:01 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
OEM windows are pretty heavy. There's an outfit that makes polycarbonate windshields, gotta save about 30lbs on the windshield alone. Spendy, though. Lexan's cheap for side glass.
Look at every piece on the car and decide if it really needs to be there or that big or heavy.
Re: Weight loss questions... [Re: sixpackgut] #1031540
07/15/11 03:02 AM
07/15/11 03:02 AM
Red Deer, Alberta
Red Deer, Alberta
I must have a light one! Iron head 360, 6 point cage, 9 inch, no wipers/motor, no heater, carpet and underlay out, no undercoat, fiberglass seats (albeit with heavy seat tracks- there's 20 lbs to be had there.),fiberglass front bumper, that's pretty much it for lightening. It's an honest 2930.
There must be 40 (?) in a hood, 50 or 60 in a deck lid, so that's a hundred tops, I guess. I've already got Wilwoods, so I'd have to put alum. heads and some lightweight front susp. hardware in to get into the 2700-2750 range, I guess.
