Re: Weight loss questions...
[Re: Thumperdart]
#1031523
07/13/11 04:08 AM
07/13/11 04:08 AM
Posts: 3,210 robin hood country
deaks
robin hood country
Alloy water pump, alloy m/c, i took around 15 lbs out of the K member, good savings on the bumper brackets, i used glass ones on the front and cut the rears in half and holesawed them out. Anti roll bar took around 12 lbs off. Your car is lighter than mine though. To get 2700, i think you would need glass doors and alloy or glass dash, pin on glass trunk lid etc. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: bill_greenwood]
#1031525
07/13/11 09:06 AM
07/13/11 09:06 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Make sure the under coating is gone, insulating mat under the carpet, lose the stock wiring harness and wire just what you need, dump the front brakes for light weight racing brakes... cut off any extra length on every bolt...light weight racing wheels and tires... dump the T-bars for coil over shocks... thats a few things ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Thumperdart]
#1031527
07/13/11 01:49 PM
07/13/11 01:49 PM
Posts: 8,165 Left Coast
BobR
Left Coast
But even with everything mentioned...........2700lbs. sounds like tube chassis territory or at least a back half.......... I`ve have everything mentioned except the deck lid and coil overs.
My tube chassis Duster(MS) weighed 2550. R/P steering, liteweight brakes, glass hood/decklid, plastic cell, ect. I really doubt one could get a stock type chassis car 2700 pounds.
#1031528
07/13/11 02:01 PM
07/13/11 02:01 PM
Posts: 248 Ohio
aquamist60
Ohio
A few years ago we took the Duster to the scales. No engine, tranny, seats, carpet, battery. Had Cragars & street tires and a 12 pt. cage, complete wiring front to back, fiberglass hood, stock bumpers, glass, frame tied, narrowed 8 3/4 rear, S/S springs. Don't remember what else was out or in. Shocked us when it weighed 2030 lbs. I expected it'd weigh more than that.
[Re: 70HemiGTX]
#1031530
07/13/11 03:29 PM
07/13/11 03:29 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
very little money involved here but it took time. lost alot of weight. i dont know if the car is going to stear right though either
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: 70HemiGTX]
#1031531
07/13/11 03:33 PM
07/13/11 03:33 PM
Posts: 16,619 Almost Heaven
B_Body_Bob
Master of nothing
Master of nothing
Almost Heaven
I pulled the dash frame out of my car. It had been trimmed up by Vanke's shop back in the 70s when the car was prepped. Compared to a stock one, there less than 2 lbs difference. Doesn't seem to be worth the effort to me, but all you have to do is lose that amount of weight in 50 places, and you've saved a 100 lbs.
Everybody makes fun of a hillbilly until they need something fixed
#1031536
07/14/11 08:57 AM
07/14/11 08:57 AM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
My 69 Dart with a aluminum headed small block, 727, aluminum radiator, Dana, bolt on 6 pack glass hood and glass front bumper, full interior with Kirkey seats, heater, wipers, factory glass and 3" exhaust to the rear end weighs 3085 without me. I lightened the front bumper brackets and saved almost 5.5#, the glass front bumper saved 20# and the bolt on glass six pack was 31# lighter than the stock flat hood. The Strange front brakes were 50# lighter than the 73 disk setup I had on it. These items alone are almost 100# with out really much work. I don't think glass fenders would save enough over the stock ones to justify the cost. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: sixpackgut]
#1031540
07/15/11 03:02 AM
07/15/11 03:02 AM
Posts: 1,730 Red Deer, Alberta
bill_greenwood
Red Deer, Alberta
I must have a light one! Iron head 360, 6 point cage, 9 inch, no wipers/motor, no heater, carpet and underlay out, no undercoat, fiberglass seats (albeit with heavy seat tracks- there's 20 lbs to be had there.),fiberglass front bumper, that's pretty much it for lightening. It's an honest 2930. There must be 40 (?) in a hood, 50 or 60 in a deck lid, so that's a hundred tops, I guess. I've already got Wilwoods, so I'd have to put alum. heads and some lightweight front susp. hardware in to get into the 2700-2750 range, I guess.
