Re: heli coil insert tool needed?
[Re: Commando1]
#1030817
07/12/11 09:25 AM
07/12/11 09:25 AM
Challenger 1
Cincinnati, Ohio
Has anybody figured out how to break off the tang in a through hole so that it doesn't fall down inside the engine?
Yes use grease on the end of your punch. The 2 auto parts stores I buy from has them in stock hanging on the wall.
[Re: BTTG]
#1030818
07/12/11 09:26 AM
07/12/11 09:26 AM
Challenger 1
Cincinnati, Ohio
Is there a separate insert tool for each size insert? will the insert tool in the 5/16-18 kit only insert those inserts?
Yes
[Re: Challenger 1]
#1030819
07/12/11 09:47 AM
07/12/11 09:47 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
insert tool can be the same bolt size you'll use but with end steped cut.
the imposible to find unless you get the kit is the thread cutter for the helicoil, since they are non commercial sizes and made just for this purpouse
[Re: Commando1]
#1030820
07/12/11 10:31 AM
07/12/11 10:31 AM
Posts: 15,487 Florida
scratchnfotraction
I have some long skinny mini needle nose pliers I have used to break off the tang.
I have broke the tang and thred them in by hand also
[Re: rbstroker]
#1030822
07/12/11 10:58 AM
07/12/11 10:58 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Is there any way to remove the helicoil after it is installed?
Yes , you need a sharp pointed pick to bend the top of the coil out far enough to grab it with pliers then you can sort of unwind it, done it many times .
[Re: rbstroker]
#1030823
07/12/11 10:59 AM
07/12/11 10:59 AM
scratchnfotraction
yes,pick at the top end of coil,grab with pliers and pull/unwind it out of the hole.
sometimes if the hole is loose it will turn back out picking at the end and turning it.
like you would a broken bolt to back it out.
faster to just pull it out and spin a new one in
i do most of my alum intakes befor ever running it,cab studs are a good place to start on an alum intake,IMO
[Re: scratchnfotraction]
#1030824
07/12/11 12:32 PM
07/12/11 12:32 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Try these and you will never use a heli-coil again. http://www.newmantools.com/kee.htm
[Re: dogdays]
#1030827
07/13/11 03:23 PM
07/13/11 03:23 PM
Challenger 1
Cincinnati, Ohio
I bought a whole kit that came in a custom box that has like 4 or 5 sizes in it. At the time when I was pricing them, it was cheaper in a kit. Have had them now for a long time, don't even remember where I got them now. But it has paid for it's self many times over.
