8 3/4 axle/housing Q's ...12 flat car ... ? #1030799
07/12/11 08:35 AM
07/12/11 08:35 AM
Florida STAYcation
dOoC Offline OP
The village idiot's idiot
dOoC  Offline OP
Florida STAYcation
..... I need two narrowed combos .. are REsplined way-shortened C-body axles OK(car should be a 3300? lbs/727/footbrake with a "nothing" converter. OR ...should I just go with some aftermarket axles? .... the housing would have to be shortened a ton ...and new pads welded-on before the new ends are put on.
Anyone here have a contact for something like this?
Re: 8 3/4 axle/housing Q's ...12 flat car ... ? [Re: dOoC] #1030800
07/12/11 10:02 AM
07/12/11 10:02 AM
ill
dennismopar73 Offline
ill
the quality of resplind axles is youre question,,on street car maynot be issue, as for a race car running 12.0s??? i have run stock axels at 11.90 and twisted them in a 3400 car,
breaking axels not what you want , so spend youre money 1 time
Re: 8 3/4 axle/housing Q's ...12 flat car ... ? [Re: dOoC] #1030801
07/12/11 10:08 AM
07/12/11 10:08 AM
Slidell, La.
doctor_mopar Offline
Slidell, La.
I had a pair of resplines in my 13 second street cuiser 67 Cuda and the splines wore considerably. They got me nervous enough, that I upgraded to a pair of aftermarket axles from the good Doctor Diff !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: 8 3/4 axle/housing Q's ...12 flat car ... ? [Re: doctor_mopar] #1030802
07/12/11 10:21 AM
07/12/11 10:21 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I ran stock resplined axels to 6.90 in the 1/8 and moser stock spline axels till a month ago, running 6.0ohs. I twisted the resplined a little then went to the good ones and now there showing a little twist so I finally decided to go to a Dana.
I would run resplined ones again in a lower powered car.
Moser will respline them but I forget what it cost.
Re: 8 3/4 axle/housing Q's ...12 flat car ... ? [Re: dennismopar73] #1030803
07/12/11 10:48 AM
07/12/11 10:48 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
that's what I'm affarid of. Ran a couple of 11.93's at 115 on "easy passes" Going to step it up next time out. I'm probably going to upgrade before then. FWIW I ran 12.0's in a 67 coronet w/ stock units w/ zero issues. Probably 50-60+ runs before I sold the car.
Coming soon!!!!
Re: 8 3/4 axle/housing Q's ...12 flat car ... ? [Re: dOoC] #1030804
07/12/11 11:32 AM
07/12/11 11:32 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Axles are cheap. Get some Dutchmans and never look back.
Re: 8 3/4 axle/housing Q's ...12 flat car ... ? [Re: dOoC] #1030805
07/13/11 02:16 PM
07/13/11 02:16 PM
Ohio
aquamist60 Offline
aquamist60  Offline
Ohio
I had an 8 3/4 out of an E body narrowed 4" per side for my A Body. We resplined the stock axles & put a stripe on each axle to easy check for twist, but I was running low 13's on street tires. Never did see any twist. now we're about to break into high 11's. The stock ones might work, but I'm maybe a little more on the cautious side. Ran with a Hemi Stock Eliminator & saw a few problems through that time.
We decided to run a spool, slicks and aftermarket axles for the extra measure of feeling safe. Just my
Re: 8 3/4 axle/housing Q's ...12 flat car ... ? [Re: aquamist60] #1030806
07/13/11 02:41 PM
07/13/11 02:41 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I had Moser respline a set for me years ago for my mild (11.80's at that time) A body. I used 3.91 gears and all seemed good for a few years. I swapped in 4.30 gears and in 2 weekends they were twisted badly.No need for a paint stripe as it's the spline area that twisted and very easy to spot. I ran 28" M/T sportsman pro tires,not slicks. I purchased new axles and had no further problems.
Re: 8 3/4 axle/housing Q's ...12 flat car ... ? [Re: goldmember] #1030807
07/13/11 03:55 PM
07/13/11 03:55 PM
Florida STAYcation
dOoC Offline OP
dOoC  Offline OP
Florida STAYcation
Well guyz .. it seems that the plan is AFTERmarket axles ferr me ...
So between Moser and Dutch ....who is the plan? ... and I would rather stick-with TIMKEN-type bearings ... who is the plan to deal-with there ....to get the stocker ends back on and the pads moved?
Does Doc Diff do this ?
Re: 8 3/4 axle/housing Q's ...12 flat car ... ? [Re: dOoC] #1030808
07/13/11 03:59 PM
07/13/11 03:59 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Dr Diff can take care of your needs.
Re: 8 3/4 axle/housing Q's ...12 flat car ... ? [Re: goldmember] #1030809
07/13/11 04:02 PM
07/13/11 04:02 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I would call dr dif. cant beat the prices and service!
67' charger 499 RB 10.57 at 127
Re: 8 3/4 axle/housing Q's ...12 flat car ... ? [Re: dragram440] #1030810
07/14/11 01:15 AM
07/14/11 01:15 AM
grande prairie , ab , canada
68notch Offline
68notch  Offline
hes got parts and prices in the diff/trans section
theres nothing as permanent as a temporary fix 70 super bee 79 red express 67 fargo 8o aspen rt
