Cutting down an 8 3/4. Cut and splice or new flanges? #1030391
07/11/11 08:20 PM
07/11/11 08:20 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Getting ready to take a C body housing in to get cut down to A body dimensions. Will they want to cut a few inches out of the two tubes and reweld the tubes together (leaving the flanges on) or just cut off the ends and reweld new flanges on?
Don't know if I need to by flanges or not.
Re: Cutting down an 8 3/4. Cut and splice or new flanges? [Re: VITC_GTX] #1030392
07/11/11 08:32 PM
07/11/11 08:32 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
They will cut the ends off and reweld them on after cutting the tubes.
Re: Cutting down an 8 3/4. Cut and splice or new flanges? [Re: VITC_GTX] #1030393
07/11/11 09:28 PM
07/11/11 09:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Most of the available new flanges only work with Green (ball) bearings, if the old ones are good reuse them for sure.
Re: Cutting down an 8 3/4. Cut and splice or new flanges? [Re: John_Kunkel] #1030394
07/11/11 11:21 PM
07/11/11 11:21 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks for the help guys.
Re: Cutting down an 8 3/4. Cut and splice or new flanges? [Re: VITC_GTX] #1030395
07/13/11 01:29 AM
07/13/11 01:29 AM
Colo Springs, Co
dragaddict Offline
super street
dragaddict  Offline
super street
Colo Springs, Co
The bearing issue has been argued to death on here for years. We cut a C body down and welded in new flanges as Moser axles run fine on green bearings. I also relocated the springs with the kit since the pads won't work now. Also did frame connectors at same time. Shocks on new angle not really a problem. Exhaust tight between stock fuel tank and relocated new springs. Typical small stuff after taking apart a old car but love the changes and fresh bushings and hardware. Car is a 69 B Body.
