Page 1 of 6 1 2 3 4 5 6
Lets hear your stupid fast 440 combo's #1029693
07/10/11 09:39 PM
07/10/11 09:39 PM
Champion City
The Sphinx Offline OP
Champion City
Post them up, I'm looking to get 10.90's in a 3000 LBS car
Re: Lets hear your stupid fast 440 combo's [Re: The Sphinx] #1029694
07/10/11 09:55 PM
07/10/11 09:55 PM
gregsdart Offline
gregsdart  Offline
piece of cake. 11/1 compression, .000 deck flat tops, mild port on iron heads, mopar 590 cam, 750 to 850 on a single plane intake, 2 x 36 to 42 x 3 1/2 collecter headers. OOTB eddies ( have em checked for tight guides, good valve job etc) will push you to mid to low tens with the 850 and 590 cam.
Re: Lets hear your stupid fast 440 combo's [Re: The Sphinx] #1029695
07/10/11 11:11 PM
07/10/11 11:11 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Not really a 440, but a 451 lowdeck, close enough.
3100 lb. race weight. This one was stupid cheap & mild but affective.
Ross FTs, 9.73 compression, 91cc head
"bone stock port" 906 heads with stock size stainless valves
XE284H in at 105.5
M1 single, swapmeet 750dp
1.7/8 FW headers with 18" extentions.
Ductile iron 1.5 rockers
MSD dig.6
Crane pushrods
727 with PTC 4400 9.5" stall
4.10 8.3/4
28" MT slicks
Timing at 20* int., 35* total, all in at around 2K
Shifted at 5600
10.91 @ 120+ Best. on a 1.51, it was on the ragged edge of a 10.89
With a PTC 11" 3000 stall ran a best of 11.12 @ 119
Around 3600.00 in engine carb too pan
Don't really need any fancy stuff like aluminum heads & big cam/carb to pull high tens at 3000 Lbs.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Lets hear your stupid fast 440 combo's [Re: joedust451] #1029696
07/10/11 11:32 PM
07/10/11 11:32 PM
Crossville,TN
526ciduster Offline
526ciduster  Offline
Crossville,TN
70 duster 3100 lbs
11.5 trw
self ported 906 heads with over size valves
comp cams 585 lift solid cam
750 dp
2" under chassis headers
stock 727 and cheapo converter
411 gears
10.80@125mph in 95 degree heat,the one and only time it ran the quarter mile.
been 20+ years ago but ran forever.
Outlaw 10.5 526ci, F3R procharged tfx hemi, Big Stuff 3 PTP RACING
Re: Lets hear your stupid fast 440 combo's [Re: joedust451] #1029697
07/10/11 11:33 PM
07/10/11 11:33 PM
Freeport, Pa
W
whiskeyrunner Offline
W
Freeport, Pa
why not smallblock?
Re: Lets hear your stupid fast 440 combo's [Re: whiskeyrunner] #1029698
07/10/11 11:43 PM
07/10/11 11:43 PM
Champion City
Champion City
why not smallblock?
I thought about it but I already have the 440 and the fenderwell exit headers.
Re: Lets hear your stupid fast 440 combo's [Re: The Sphinx] #1029699
07/11/11 02:05 AM
07/11/11 02:05 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
There an old post on here about fast 3.75''-stroke 440 combo's?that might help.
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Lets hear your stupid fast 440 combo's [Re: 67mprfan] #1029700
07/11/11 02:43 AM
07/11/11 02:43 AM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
My dads duster went 10.38 with a 440 OOTB eddys 3400lbs.
Re: Lets hear your stupid fast 440 combo's [Re: ChrisJohnston669] #1029701
07/11/11 08:55 AM
07/11/11 08:55 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
12.5 to 1 stock stroke 440
906 heads with Entry Level FAST porting by Dwayne Porter
Custom Solid Roller by Porter
Exhaust manifolds and Dynomax mufflers
3,850LB 69 Six Pack Superbee
Stock Hemi 4-speed with Centerforce clutch
On hard street tires went 11.80's @ 119 first time out........Take out 850LBS and it'd run 127+ which is enough for 10.30's with slicks and an automatic, and that's through exhaust manifolds......
If you can't handle the truth, you're living a lie.......
Re: Lets hear your stupid fast 440 combo's [Re: gregsdart] #1029702
07/11/11 01:30 PM
07/11/11 01:30 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Yep, what he said! Almost too easy. In fact, at a true 3000# race weight, I bet with the RIGHT converter/gear, it should go in the 10's with a HYDRAULIC stick...like even the old MP 509!
My last 440 was .030 over, TRW fat tops, Crane roller, 250" cfm 906 heads...at 3200#...10.28 @ 128 best lap.
Re: Lets hear your stupid fast 440 combo's [Re: whiskeyrunner] #1029703
07/11/11 01:43 PM
07/11/11 01:43 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
why not smallblock?
Because small blocks are for girls and old people.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Lets hear your stupid fast 440 combo's [Re: pittsburghracer] #1029704
07/11/11 02:20 PM
07/11/11 02:20 PM
Get-X Offline
Get-X  Offline
why not smallblock?
LOL!!
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Lets hear your stupid fast 440 combo's [Re: whiskeyrunner] #1029705
07/11/11 02:23 PM
07/11/11 02:23 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
why not smallblock?
because unless it's an a-body or a superlight car you'l spend twice as much to make it fast.
Coming soon!!!!
Re: Lets hear your stupid fast 440 combo's [Re: whiskeyrunner] #1029706
07/11/11 02:47 PM
07/11/11 02:47 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
why not smallblock?
i agree my 418ci eddy was faster than all the 440's posted here and that was 3200lb pumpgas,,,i dont wanna tell u how much faster my 440ci sb is compared to the others
Re: Lets hear your stupid fast 440 combo's [Re: fishy340] #1029707
07/11/11 03:21 PM
07/11/11 03:21 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
why not smallblock?
418? Im not a small block guy but isnt that a stroker? So that would involve crank rods and pistons? My 499 RB makes more power then them there big block combos!
67' charger 499 RB 10.57 at 127
Re: Lets hear your stupid fast 440 combo's [Re: fishy340] #1029708
07/11/11 03:36 PM
07/11/11 03:36 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
why not smallblock?
yeah and do a 440 next time and you tell me which is faster...if you can peal the smile off ur face. apples and oranges. Takes a lot of work, like crank, ported heads, big cams, expesive converters, headers and gear for a SB to run w/ a BB. Not saying it can't be done but $ for $ a 440 is a great place to start for a drag car.
Re: Lets hear your stupid fast 440 combo's [Re: The Sphinx] #1029709
07/11/11 03:43 PM
07/11/11 03:43 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Stock stroke 440. H-beam rods, Ross 11:1 pistons, ported stealth or e-heads (OOTB) heads, 620ish cam, TM-7 intake, 950HP carb, 4200 stall, and 4.30's should get you there easy. Nothing fancy to it.
Re: Lets hear your stupid fast 440 combo's [Re: The Sphinx] #1029710
07/11/11 03:53 PM
07/11/11 03:53 PM
Champion City
Champion City
I have nothing against small blocks, I have 3 other cars with small blocks with the slowest one at 375HP and the quickest at 510HP. All I know is SB's, I just need a change, no pissing match.
Keep the combo's coming!
Re: Lets hear your stupid fast 440 combo's [Re: The Sphinx] #1029711
07/11/11 04:17 PM
07/11/11 04:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A mild 440 with a decent cam, .640 and a little port
work on the heads with a decent converter should do
it easy
EDIT
all it takes is about 420 HP
Re: Lets hear your stupid fast 440 combo's [Re: MR_P_BODY] #1029712
07/11/11 04:27 PM
07/11/11 04:27 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
it easy
EDIT
So you could do it with detuned stock 426 ?
