opinions on intakes for my 440 combo #1029641
07/10/11 08:34 PM
07/10/11 08:34 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
im doing some updates on my combo and am wondering if there would be a better intake for my 440 rather than my torker 2
3500lb race weight dart sport, street/strip
440 11.0CR
ported stealth heads
solid flat tappet 250 255 530 540 108 cam
2 inch pro parts into 3inch x system
727 with 9 inch converter that is going to turbo action for a stall change 4k?
3.70 gear with 26 inch slicks. posible 410/28inch later
would a victor be an option? i think i have access to an original torker..? id like to be on the "racier" side of the combo..
74 dart sport 440 www.Csucarbs.com
Re: opinions on intakes for my 440 combo [Re: shoebox] #1029642
07/10/11 08:44 PM
07/10/11 08:44 PM
Cab_Burge Online work
Cab_Burge  Online Work
I dyno tested a Torker 2, Mopar M1 4150 single plane and a Edelbrock Performer RPM on the same engine the same day, about 20 minutes each to change them, with no other changes. The torker 2 was the worst by about 20 HP and 25 Ft Lbs torque, the M1 and RPM where close to the same on the average readings from 3000 to 6500 RPM, the RPM was beter below 5000 RPM and the M1 was better above 5000 RPM If race only the M1 would be my choice, if street and strip I would use (do and have) the RPM intake I have not used the other intakes you ask about, sorry EDIT, I sure wish they had spell check on here maybe I should proof read better
Re: opinions on intakes for my 440 combo [Re: Cab_Burge] #1029643
07/10/11 09:15 PM
07/10/11 09:15 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
i know intakes for these engines have die hard followers
m1 is always popular and in the mix
lot of guys like the torker or like tm7 type manifolds
rpm is a classic
i want the car to lean a lil more to "race" due to its a weekend toy that i want to drive to the local 1/8th mile track do as best as possible and drive home in one piece!
torker2 will allow me to keep my nice flat hood altough a 5inch six pack lift off would look cool!
maybe i can port the snot out of the torker 2? get close to that 20 hp back?
Re: opinions on intakes for my 440 combo [Re: shoebox] #1029644
07/10/11 09:18 PM
07/10/11 09:18 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Look for a TM-7 or a M-1..different animal than the Torker 2.
Nautilus Racing-
Re: opinions on intakes for my 440 combo [Re: Chris2581] #1029645
07/10/11 09:31 PM
07/10/11 09:31 PM
Central NC
gch Offline
gch  Offline
Central NC
Want to keep the flat hood?Then consider the Holley street dominator.Should respond well to a spacer if clearance allows but will pull hard w/o one.
I would run the 28" tall tire with either gear.It will be easier to hook.
Re: opinions on intakes for my 440 combo [Re: gch] #1029646
07/10/11 09:37 PM
07/10/11 09:37 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
My torker2 is pretty nice. What do you think i could ask for it?
Re: opinions on intakes for my 440 combo [Re: shoebox] #1029647
07/10/11 09:47 PM
07/10/11 09:47 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
My fastest run ever in my car was with a torquer II...I think it's a good intake. I'd stick with it or use a Holley SD.
Torquer II Intake is probably worth $80-100.
Re: opinions on intakes for my 440 combo [Re: Quicksilver440] #1029648
07/10/11 10:11 PM
07/10/11 10:11 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
The SD is always highly reveered. I dont think ive ever heard a
Negative comment about it. The torker2 is free, clears the hood
And can be ported
Re: opinions on intakes for my 440 combo [Re: Quicksilver440] #1029649
07/10/11 10:25 PM
07/10/11 10:25 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
I think you are right if you run a 4150 intake TORQUER II it just worked better for me to good luck
Re: opinions on intakes for my 440 combo [Re: steeldust] #1029650
07/10/11 10:27 PM
07/10/11 10:27 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I really liked the Holley Street Dominator I ran on my old 440. Ron
Re: opinions on intakes for my 440 combo [Re: shoebox] #1029651
07/11/11 08:25 AM
07/11/11 08:25 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
The RPM is a good intake but as mentioned it is TALL and if you want to run a flat hood you might have issues.
Coming soon!!!!
Re: opinions on intakes for my 440 combo [Re: Mr.Yuck] #1029652
07/11/11 11:22 AM
07/11/11 11:22 AM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
Hot Rod did some manifold comparisons a few years ago. You might want to read up on their results and see how it might apply to your setup.
http://www.hotrod.com/techarticles/hrdp_0712_mopar_intake_manifold_comparo/index.html
http://www.hotrod.com/techarticles/hrdp_0801_mopar_intake_manifolds/index.html
Re: opinions on intakes for my 440 combo [Re: shoebox] #1029653
07/11/11 12:53 PM
07/11/11 12:53 PM
B.C. Canada
hankcrank Offline
hankcrank  Offline
B.C. Canada
I used a TM7 a Torker(not a Torker2) and a M1 on a mild 440 with no other changes on a drag only car and the TM7 and Torker(not a torker2) there was no noticable difference but the M1 gained 2-3 tenths on my specific combo.Hope this helps.
Re: opinions on intakes for my 440 combo [Re: hankcrank] #1029654
07/11/11 01:03 PM
07/11/11 01:03 PM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
I have ran the Torker II with great results, so
for my next motor i'm running a Victor.
Re: opinions on intakes for my 440 combo [Re: 383man] #1029655
07/11/11 04:48 PM
07/11/11 04:48 PM
USA
BB Dart 69 Offline
BB Dart 69  Offline
USA
Best there is
Re: opinions on intakes for my 440 combo [Re: BB Dart 69] #1029656
07/11/11 05:46 PM
07/11/11 05:46 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Ding ding.
Re: opinions on intakes for my 440 combo [Re: RemCharger] #1029657
07/11/11 06:35 PM
07/11/11 06:35 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Holley if you can find one.
Re: opinions on intakes for my 440 combo [Re: Biginchmopar] #1029658
02/20/12 01:33 PM
02/20/12 01:33 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
its not in my hands yet but im supposed to get a weiand tunnel ram! i think its a "hi ram". my converter is going to lenny to get up'd to 4500-4800. i talked to my carb guy.. a pair or 650-750 double pumpers outta get it done! man im excited! ill get to really use my 70s pro stock scoop i want! some of my heros here on the board have the TR in A bodies! clovis, mopar65 and ari440 all 10s or better!
