Re: What to use for painting open trailer
[Re: BryanRad]
#1028952
07/09/11 06:20 PM
07/09/11 06:20 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I have a all steel open trailer.The deck is coated with bed liner,and the frame was wire brushed and all rust removed,primed with RustOleum red primer,then RustOleum gloss black paint.I primed the deck before applying the bedliner(I used PlastiKote in a 1 gallon can)which I sprayed on using a undercoat gun.The trailer was built in 1982 and I had to finally remove the diamond plate steel 3 years ago.I did the work on the frame while the bed was off,and then painted it after the new steel deck was put on.The RustOleum has done very well,and I applied primer and paint with a 4" brush.
[Re: BryanRad]
#1028955
07/09/11 07:12 PM
07/09/11 07:12 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I think its oil base... I just brush it on.... or 3 other choices... machine paint, tractor oil base paint or POR 15 (I use a off brand called Chassis Saver) the tractor paint I get at TSC works very well also ![](/ubbthreads/images/graemlins/wave.gif)
[Re: BryanRad]
#1028959
07/09/11 08:49 PM
07/09/11 08:49 PM
MR_P_BODY
Mr. P, do you like the rustoleum or TSC paint better (have one of those 10 minutes up the road).
I painted one of my tractors with the TSC tractor paint and it still looks good today... that was 14 years ago so over all I like the tractor paint best... oh yeah that tractor sits out side all the time(its actually a crawler loader so it has steel tracks)so it dont go in the pole barn
[Re: MR_P_BODY]
#1028961
07/09/11 10:36 PM
07/09/11 10:36 PM
Posts: 4,675 Ortonville, MI
RoadRnnr69
Keyster
Keyster
Ortonville, MI
I beleive POR 15 cannot be in direct sunlight, no UV protection but not sure about Chassis Saver brand. I brush oil Rustoleum on all my trailers, it works great. I put it on thick and it resists chipping and scratches.
[Re: Chris2581]
#1028963
07/09/11 11:15 PM
07/09/11 11:15 PM
Posts: 437 south central pa
bdaz smblk
south central pa
Hey Bryan good to see u back on here.How is the wife doing now from the accident.Hope all is well. ![](/ubbthreads/images/graemlins/luck.gif) Kenny
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: BryanRad]
#1028964
07/09/11 11:35 PM
07/09/11 11:35 PM
MR_P_BODY
Any chance you recall whether it was the Valspar they carry now?
Not sure... maybe I can find the can tomorrow ![](/ubbthreads/images/graemlins/wave.gif)
[Re: RoadRnnr69]
#1028965
07/10/11 07:33 AM
07/10/11 07:33 AM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
correct.
