What to use for painting open trailer #1028950
07/09/11 05:41 PM
07/09/11 05:41 PM
Ripley
BryanRad Offline OP
BryanRad  Offline OP
Ripley
I have an open deck (all steel) car trailer that is about 8 years old and needs repainting. What have you guys used that you have had success with? I have a Graco airless sprayer and plan to spray whatever I use, just cant decide what type of paint. Have seen good and bad things about implement paint and was considering and industrial, oil based paint.
Re: What to use for painting open trailer [Re: BryanRad] #1028951
07/09/11 06:02 PM
07/09/11 06:02 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Mine's painted with a catalyzed single-stage urethane, to match my (white) Dually. Ramps & deck surface for the tires are sprayed bedliner. Middle of the trailer is fairly thin bare aluminum to keep road grit & debris off the underside of the cars.
Probably a gallon of paint on the whole thing; didn't paint the center or where the bedliner is. The bedliner was about $200, and maybe $100 for paint. Prepped it myself & traded out the paint & bedliner labor, which would've been about 12 hours total (masking & spraying both). I had the local "ClearBra" guy put that clear film on the fronts of the fenders to minimize stone damage, which was about $60.
Re: What to use for painting open trailer [Re: BryanRad] #1028952
07/09/11 06:20 PM
07/09/11 06:20 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I have a all steel open trailer.The deck is coated with bed liner,and the frame was wire brushed and all rust removed,primed with RustOleum red primer,then RustOleum gloss black paint.I primed the deck before applying the bedliner(I used PlastiKote in a 1 gallon can)which I sprayed on using a undercoat gun.The trailer was built in 1982 and I had to finally remove the diamond plate steel 3 years ago.I did the work on the frame while the bed was off,and then painted it after the new steel deck was put on.The RustOleum has done very well,and I applied primer and paint with a 4" brush.
Nautilus Racing-
Re: What to use for painting open trailer [Re: Chris2581] #1028953
07/09/11 06:38 PM
07/09/11 06:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I like good old Rustoleum... prime it after scuffing the
loose stuff off and them Rustoleum black
Re: What to use for painting open trailer [Re: MR_P_BODY] #1028954
07/09/11 06:51 PM
07/09/11 06:51 PM
Ripley
BryanRad Offline OP
BryanRad  Offline OP
Ripley
The Rustoleum oil based, high performance?
Re: What to use for painting open trailer [Re: BryanRad] #1028955
07/09/11 07:12 PM
07/09/11 07:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think its oil base... I just brush it on.... or
3 other choices... machine paint, tractor oil base
paint or POR 15 (I use a off brand called Chassis Saver)
the tractor paint I get at TSC works very well also
Re: What to use for painting open trailer [Re: MR_P_BODY] #1028956
07/09/11 07:27 PM
07/09/11 07:27 PM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
Rustoleum, you can brush or roll it on, sprays okay too when thinned with cheap laquer thinner. You need to strain it twice if spraying, and use a big tip. If you want to sand, prime, sand and make it pretty, use Industrial Imron for an inexpensive catylized urethane.
Re: What to use for painting open trailer [Re: BryanRad] #1028957
07/09/11 07:35 PM
07/09/11 07:35 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
i would use eastwoods rust encapsulator. i painted a railing years ago & it still hasn't rusted. no creeping rust either. it's a little pricey, but worth every penny. they have all good products. stay safe, seeya.
Re: What to use for painting open trailer [Re: rickraw] #1028958
07/09/11 07:45 PM
07/09/11 07:45 PM
Ripley
BryanRad Offline OP
BryanRad  Offline OP
Ripley
Mr. P, do you like the rustoleum or TSC paint better (have one of those 10 minutes up the road).
Re: What to use for painting open trailer [Re: BryanRad] #1028959
07/09/11 08:49 PM
07/09/11 08:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I painted one of my tractors with the TSC tractor paint
and it still looks good today... that was 14 years ago
so over all I like the tractor paint best... oh yeah
that tractor sits out side all the time(its actually
a crawler loader so it has steel tracks)so it dont
go in the pole barn
Re: What to use for painting open trailer [Re: MR_P_BODY] #1028960
07/09/11 10:32 PM
07/09/11 10:32 PM
Ripley
BryanRad Offline OP
BryanRad  Offline OP
Ripley
Any chance you recall whether it was the Valspar they carry now?
Re: What to use for painting open trailer [Re: MR_P_BODY] #1028961
07/09/11 10:36 PM
07/09/11 10:36 PM
Ortonville, MI
RoadRnnr69 Offline
Keyster
RoadRnnr69  Offline
Keyster
Ortonville, MI
I beleive POR 15 cannot be in direct sunlight, no UV protection but not sure about Chassis Saver brand.
I brush oil Rustoleum on all my trailers, it works great. I put it on thick and it resists chipping and scratches.
Re: What to use for painting open trailer [Re: BryanRad] #1028962
07/09/11 10:45 PM
07/09/11 10:45 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Yes that is what I used.Both primer and topcoat.
Nautilus Racing-
Re: What to use for painting open trailer [Re: Chris2581] #1028963
07/09/11 11:15 PM
07/09/11 11:15 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
Hey Bryan good to see u back on here.How is the wife doing now from the accident.Hope all is well. Kenny
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: What to use for painting open trailer [Re: BryanRad] #1028964
07/09/11 11:35 PM
07/09/11 11:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Not sure... maybe I can find the can tomorrow
Re: What to use for painting open trailer [Re: RoadRnnr69] #1028965
07/10/11 07:33 AM
07/10/11 07:33 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
correct.
Re: What to use for painting open trailer [Re: POS Dakota] #1028966
07/10/11 08:05 AM
07/10/11 08:05 AM
Ripley
BryanRad Offline OP
BryanRad  Offline OP
Ripley
Thanks for the information, everyone.
Kenny,
She is doing a lot better, thanks. A few small issues now but for the most part fine. We bought her another car on Friday. Picked it up at that Honda dealership near Mason Dixon. Thanks for asking. How is your family?
Bryan
