03 intrepid 2.7 a good motor? #1028921
07/09/11 04:35 PM
07/09/11 04:35 PM
South Jersey
6packattack Offline OP
South Jersey
Thanks for the replies. I once owned a 1999 intrepid with the 2.7 and after 120,000 the motor started smoking but other than that i really like the style and car. Now looking at a one owner used 2003 intrepid SE with 115,000 and the 2.7 v6. Car is super clean with all options except moonroof and everything functions great and no smoke. Guy said the 2.7 had a newer configuration?? Any mopar techs out here that can give me some feed back on these motors? I'd rather it had the 3.5 but not the case...Thanks
Asking price is 3,700
Re: 03 intrepid 2.7 a good motor? [Re: 6packattack] #1028922
07/09/11 04:44 PM
07/09/11 04:44 PM
minnarusta
TX9H6E4CUDA Offline
TX9H6E4CUDA  Offline
minnarusta
Don't do car, Get a 3.5 car. You have already been a victim of a 2.7 why do it again. There is nothing new about the 03 2.7 and they are a problem child still. Now someone will come on here and say their neighbors, cousins, uncles, sister, third removed step child had one that was problem free, well my info is from the hundreds of 2.7 cars I have seen go to the shredder because of engine problems. Don't do it
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: 03 intrepid 2.7 a good motor? [Re: TX9H6E4CUDA] #1028923
07/09/11 04:56 PM
07/09/11 04:56 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Forest The whole timing chain setup is a major PITA. Oiling system is inadequate causing them to sludge up and self destruct with low miles.
Re: 03 intrepid 2.7 a good motor? [Re: 6packattack] #1028924
07/09/11 05:22 PM
07/09/11 05:22 PM
US of A
A38s! Offline
A38s!  Offline
US of A
You a gamblin' man?
I have to 3x that. Even if the timing and PITA h2o pump have been gone through recently, w/o a sludge answer, the clock is already ticking down. JY Mopar sections are filled with less than 10 yr old 2.7s LHs with loose plenums.
Conversely, body parts are plentiful...
Re: 03 intrepid 2.7 a good motor? [Re: A38s!] #1028925
07/09/11 06:06 PM
07/09/11 06:06 PM
South Jersey
South Jersey
Ok thanks for the heads up on the 2.7's fella's. Dam nice car and in the color I want but to bad the motor is a shitter...
Re: 03 intrepid 2.7 a good motor? [Re: 6packattack] #1028926
07/09/11 07:08 PM
07/09/11 07:08 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
They should hang the dumb SOB that designed that engine.It is one of the biggest pieces of junk ve ever seen.Id buy an old GM Bad head gasket Quad 4 before I bought one of those.Rocky
Chrysler Firepower
