New Best in the 10's and 4-Link Q's..... #1028619
07/09/11 12:28 AM
07/09/11 12:28 AM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Well it alive and back in action. For any that know what happened to the car last week, the trans exploded in spectacular fashion and Paul got hurt and ended up in the ER with 2 breaks in his foot and probably needs surgey, but should be ok. I was supposed to be driving, but glad I wasn't.
It now has a sheild on it, and a new trans, new floor, lots of new stuff and the steering column was moved to be above the knee bar..
First, I will say this, I have never, until today, run 10's....I made three runs in the car today, the first one was a feeler to get an idea, and the next two I stepped on it. I ran a 10.76, a 10.56 and a 10.56 at 127.98. Here is the kicker, the 60ft is only 1.54 and the car is unloading and pulling to the right off the launch. Its a four link, and I am thinking based on what the chassis guy said of lengthing the upper left bar, does this sound right, nevr had a 4-link before?
Also, what tire pressure in a 17x33 slick in a door car?
Re: New Best in the 10's and 4-Link Q's..... [Re: Dragula] #1028620
07/09/11 02:53 AM
07/09/11 02:53 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
Nice car, you did alot of work to it in a week......sorry cant answer your 4 link question..
Re: New Best in the 10's and 4-Link Q's..... [Re: 70blackfish] #1028621
07/09/11 09:04 AM
07/09/11 09:04 AM
Guitar Jones Offline
This is how I set my car up initially. I adjusted all the bars so they were the same length. The bottom bars pretty much just set the wheelbase. I then adjust the top bars evenly to get about 1 degree of pinion angle (I like to have some angle just to work the joint). Then I jack the rear up on the driveshaft hoop and set the front end height so it sits level. Then I let the rear down and jack the front end up on a piece of tubing so it can lean either way until the front tires just barely touch. Then shorten the top right bar until I get the right front tire 1.5 inches off the ground when the left front is just touching. Recenter the rear end if you're using a track locator bar. Depending on how much power you're making you may need to add more preload or take some out. I also found it's important to recenter the rear when using a track locator bar after each adjustment.
This should get you in the ball park.
As for tire pressure you'll have to experiment. I started with 9 pounds in mine and then changed it in .5 pound increments to get my best 60' time.
Re: New Best in the 10's and 4-Link Q's..... [Re: Dragula] #1028622
07/09/11 09:07 AM
07/09/11 09:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
When you SHORTEN the upper right bar it pushes down
harder on the right rear tire... thats how we adjust
more pre-load into it... pre-load is added to correct
a launch issue(pulling to the right)... I would say
you need a anti roll bar if its not pulling to the
right on the launch.... but from the sounds of it...
it should be pulling hard right and adding pre-load
should/would correct it... myself I'm a FIRM
believer in the anti-roll bar on a 4-link
Re: New Best in the 10's and 4-Link Q's..... [Re: MR_P_BODY] #1028623
07/09/11 11:03 AM
07/09/11 11:03 AM
Dragula Offline OP
Dragula  Offline OP
We may run the Gasser series race today and I want to try correcting it this morning, but what your saying is since it pulls right, and the left tire is planted better, pre load the right more by shortening the upper right bar, correct?
Re: New Best in the 10's and 4-Link Q's..... [Re: MR_P_BODY] #1028624
07/09/11 11:36 AM
07/09/11 11:36 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
The front of the car looks a little high to me,do you have any frontend travel left or is it against the stops.You should be able to jack the frontend up with a jack about 4 or 5 inches before the tires lift off the ground.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: New Best in the 10's and 4-Link Q's..... [Re: moparmxz] #1028625
07/09/11 12:00 PM
07/09/11 12:00 PM
Dragula Offline OP
Dragula  Offline OP
That pic is a couple weeks old. Its been to the chassis shop and sits a lot different now. It has new rear springs, different shock location, changed the pinion angle, etc....Just pulls right on the launch everytime.
Re: New Best in the 10's and 4-Link Q's..... [Re: Dragula] #1028626
07/09/11 12:10 PM
07/09/11 12:10 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Shorten the top right bar a flat or two
Re: New Best in the 10's and 4-Link Q's..... [Re: Dragula] #1028627
07/09/11 12:51 PM
07/09/11 12:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes
Re: New Best in the 10's and 4-Link Q's..... [Re: SB412DUSTER] #1028628
07/09/11 12:51 PM
07/09/11 12:51 PM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
Here,s how i remember the preload adjustments,if it goes left you lenghten the the top right bar. If it goes right you tighten the bar(shorten it).So righty tighty lefty loosey , Good luck
Re: New Best in the 10's and 4-Link Q's..... [Re: Dragula] #1028629
07/09/11 02:54 PM
07/09/11 02:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Nice car and congrats on the 10.............as far as suspension,no clue as I run Cal-Tracs and rancho shocks.
Re: New Best in the 10's and 4-Link Q's..... [Re: SB412DUSTER] #1028630
07/09/11 07:35 PM
07/09/11 07:35 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
yea what he said
Re: New Best in the 10's and 4-Link Q's..... [Re: fishy340] #1028631
07/10/11 10:55 PM
07/10/11 10:55 PM
Dragula Offline OP
Dragula  Offline OP
yea what he said
Will do. Didn't get to run Saturday as I had hoped, but we will next weekend.
Also, this is a pump gas ride, and we are looking to go very low 10's, stay tuned....
