Re: milled 915
[Re: R/T1968R/T]
#1028409
07/09/11 02:12 AM
07/09/11 02:12 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
I have a set thats milled .060. I cant remember the ccs, but it has to be in the low 70s at least. Im sure you can take it down more, but milling the intake face and lining everything up begins to get tricky.
and expensive, i have a set that are just milled to clean they came in at 80cc, with valves that are not concaved i bet they would be right around 78cc
Re: milled 915
[Re: moretork03]
#1028410
07/10/11 01:30 AM
07/10/11 01:30 AM
Posts: 1,395 LAKE TEXOMA
oldman
LAKE TEXOMA
It will also depends on what pistons you have ,you can check what you have now with clay put your clay on top of piston and bolt on head turn over and measure also you can adjust a little with different head gasket thickness, but as stated you'll have to mill the intake ,I have noticed that even some heads, that have just been surfaced makes it hard to bolt up some of the new aluminum intakes.
you never walked in that mans shoes or seen things through his eyes and stood and watched with helpless hands while the heart inside you dies, but for the grace of god it could be you instead of him.
Re: milled 915
[Re: moretork03]
#1028414
07/11/11 12:40 AM
07/11/11 12:40 AM
DaytonaTurbo
Manitoba, Canada
i wonder if there is a way to tell how much my heads were cut? trying to determine how much compression was gained, its matched with a TM7 intake
If you CC the heads there's a formula to figure out how much they've been milled. I think the head thickness can also be measured but I don't know what the spec is.
Re: milled 915
[Re: DaytonaTurbo]
#1028415
07/11/11 12:41 AM
07/11/11 12:41 AM
Posts: 75,042 U.S.S.A.
JohnRR
U.S.S.A.
I've heard of some guys cutting .100-.120 off 452's to really cut their chambers down to size for use on smogger low-cr big blocks. The problems are like said, getting the intake and valley tray to line up, valvetrain geometry becomes an issue because you really need shorter pushrods by that point and lastly by that much milling the heads become very crack prone.
You almost have that correct, valvetrain geometry is not affected by milling the deck surface of the heads. One can mill the deck surface all they want , the rocker to valve geometry NEVER changes, the only thing that changes is pushrod length.
If this were something that had rocker attachment like a smallblock chevy then yes you will change the valvetrain geometry if you don't get a shorter pushrod.
Re: milled 915
[Re: moretork03]
#1028416
07/11/11 12:43 AM
07/11/11 12:43 AM
JohnRR
U.S.S.A.
Measure the head bolt boss under the exhaust manifold mounting surfacing , factory they seem to come in right about 1.000
