Stroker Hemis, What do you have?
#1027446
07/06/11 11:33 PM
07/06/11 11:33 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
I'm bored tonite waiting on parts for my 528. Don't know what kind of response I'll get but I'll ask anyway. What size, what engine package, HP, 1/4 mile performance, what chassis? Can't remember if there has been a post devoted only to this, Wedges need not apply. Dave
Re: Stroker Hemis, What do you have?
[Re: hemi-itis]
#1027448
07/07/11 12:08 AM
07/07/11 12:08 AM
Posts: 12,387 Taxes & Virus's R-US, NY
Dragula
484 cubes with a 4.15" crank and 4.310" pistons at 11.6:1 on pump. Should be good for 9.80-9.90 in my '70 Cuda that weighs 3240lbs in pro street trim...In the middle of putting it back togather, I kept having oiling issues to the push rods.
I also drive a '70 Charger with a mild hemi that is at the same cubes (484) after the last rebuild and a solid .560 cam, 10.5:1 and a Ray Barton intake with a 950 carb on pump gas, and weighing in at 4010lbs with driver, I have netted an 11.13 on drag radials...Nearly stock config and is driven almost daily.
[Re: hemi-itis]
#1027449
07/07/11 12:14 AM
07/07/11 12:14 AM
Posts: 8,846 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
the stroke in mine is only 4.225 wich i think comes out to like 488 cubes id love to be able to say it 500+ cubes dont have any rods/pistons yet so maybe i can find a nice 4.500 stroke crank when go to nats lol
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: quickd100]
#1027450
07/07/11 01:24 AM
07/07/11 01:24 AM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Sold my 472 before I finished the car. New mill is 572" 4.5" X 4.5" World alum block, Stage V heads & rockers, CNC work by MCH, 10.5 CP pistons, K1 crank & 7.100" rods. Custom Solid Roller from Dwayne Porter, choice of two intakes , Indy single, or Old Rat Roaster X Ram, with 770 Holleys. Chassis is a Art Morrison with 71- 72 Pinto Spindles, ladder bars and Dana 60 rear with 4.10 gears. 727 trans with PTC converter. The body has glass front end, doors, and quarters. I haven't run the engine yet probably wait til fall. Too hot now. The car is apart for painting. How fast? Good question!
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#1027451
07/07/11 03:09 AM
07/07/11 03:09 AM
Posts: 1,260 Netherlands
72Challenger
Netherlands
528ci Hemi, 4.50 bore x 4.15 stroke in a KB alloy block. Steel rods with forged pistons, pumpgas comp ratio topped with '66 alloy heads ported w/ stock rockers. Barton single intake w/ 1050 dominator. Solid flat tappet cam .667 lift 283 dur@050. Backed up by a GForce 4speed with Advanced Clutches package, Dana60 4.56 gearing. Dropped in a frame rails / chassis 8.5cert. Challenger RT running a best of 9.21@149mph on it's 2nd full 1/4m run.
[Re: 72Challenger]
#1027452
07/07/11 03:22 AM
07/07/11 03:22 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
572, World block, StageV heads and intake, Crane roller cam, 9.5-1 MP pistons, stock rockers with Dvorak stands and Dechelles shafts, K1 rotating assy, 6.86-1.031 rods. Needs assembly when it cools down. Tim
[Re: astjp2]
#1027453
07/07/11 07:15 AM
07/07/11 07:15 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
494,500,526,528,540,572,588,605,632,
[Re: B G Racing]
#1027454
07/07/11 07:45 AM
07/07/11 07:45 AM
quickd100
nielsville, minn.
OK Bob, UNCLE!, you win . Dave
[Re: B G Racing]
#1027455
07/07/11 08:51 AM
07/07/11 08:51 AM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
home of the Sox and Martin Hemi Duster
[Re: BobR]
#1027457
07/07/11 11:25 AM
07/07/11 11:25 AM
Posts: 114 Crossville,TN
526ciduster
Crossville,TN
511 ci, tfx block, aj stage 2 heads, f3r procharger.
Outlaw 10.5
526ci, F3R procharged tfx hemi, Big Stuff 3
PTP RACING
[Re: CRE2004]
#1027460
07/07/11 01:45 PM
07/07/11 01:45 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
68 Dart GTS H-code
combo as of now, might be time for some changes this winter....
505 CI HEMI machined and built by me mega block, 4.400 bore 4.150 stroke eagle crank diamond custom pistons, 10.7:1 1/16 1/16 3/16 moly rings manly H-beams 6.865 Bob Weight 2627 Schneider Solid Roller custom ground 260/266 .620/.600 @ 112 BMS roller rockers 1.53 intake / 1.57 exhaust Smith Brothers pushrods MP Iron Heads, mild hand port and bowl work MP cross ram, port matched. 2 Holley 770 cross ram carbs Charlies 10 Quart oil pan w/ milodon single line external swinging pickup MSD 6AL W/blaster coil AC R44-XLS plugs (cheap and easily available) Holley HP150 pump no return/ using stock gas tank
727 built by my Father alum front drum A&A valve body 9" J-Converter
Dana 60 Detroit locker 4.56 gears W Strange 35 spline axels
Caltrac's with mono leafs Rancho adjustable shocks on rear Calvert 90/10's up front with RMS tubular uppers and strut rods
Car weighs 3780 with a Half tank of gas and my ass in the seat
leaving from idle off foot brake
60'......1.446 330.....4.255 1/8.....6.605 MPH...104.54 1000...8.636 1/4.....10.359 MPH...130.38
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: 572charger]
#1027462
07/07/11 03:32 PM
07/07/11 03:32 PM
Posts: 4,179 California
mickm
California
540 incher in the works: mopar siamese block 4.5 bore X 4.25 stroke 7.1 inch rods from FHO CP pistons 10.25:1 stage V heads ported prepped by FHO OEM style rocker also from FHO stage V dual inline intake 650 eddy carbs haven't decided on a cam yet. either (not exact numbers) hydraulic flat tappet - 240 @ .50 .560 113 lsa or similar but slightly more aggressive solid flat tappet or roller, don't know specs yet i can only get ~10" of tire under the rear without mods that i'm not up for now, and the 472 in there now tears them up, so even with the hydraulic flat tappet i'm still going to have more power than i can hook with. but on the other hand, can you ever have too much power? so i may still go roller...
