Anyone use Isky 8005A valve springs? #1027143
07/06/11 01:24 AM
07/06/11 01:24 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I was looking at these valve springs for a hydraulic roller cam in my 440. Anyone ever use these or other Isky valve springs?
Re: Anyone use Isky 8005A valve springs? [Re: 451Mopar] #1027144
07/06/11 01:27 AM
07/06/11 01:27 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been using Isky springs for years and the 8005`s w/a stout solid cam but not sure if they`re up to par w/a hydro roller. I`d call Isky and ask for Rod that way there`s no guessing.
Re: Anyone use Isky 8005A valve springs? [Re: Thumperdart] #1027145
07/06/11 01:39 AM
07/06/11 01:39 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Have a set in my Eddy-head 446" RB, good spring. Gonna get a set for my new 448" Stealth-head RB. Both are hydraulic flat-tappet motors. It's a 400#/inch double spring, 135lbs @ 1.875, 395 lbs @ 1.225, coil bind @ 1.16. Good up to .650 lift.
Re: Anyone use Isky 8005A valve springs? [Re: topside] #1027146
07/06/11 02:20 AM
07/06/11 02:20 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
There ya go...........
Re: Anyone use Isky 8005A valve springs? [Re: Thumperdart] #1027147
07/06/11 02:31 AM
07/06/11 02:31 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Can't beat the Isky 8005A springs, had them on my 451 & tons of passes on them
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Anyone use Isky 8005A valve springs? [Re: Thumperdart] #1027148
07/06/11 02:55 AM
07/06/11 02:55 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
First, what retainers are you using? When a checked Summit for retainers with 1.110" OD inner spring, the selection was some of the more expensive retainers?
If I go with a 1.095" inner step, the Comp 748-16 is only $51.95 / set.
Anyhow, I am looking at the Comp XR286HR cam and they recommend the 925-16 dual springs or the 26120-16 beehive springs.
Here is how the comp compares to the Isky"
Number 925 26120 8005A
Rate 395# 370# 400#
Closed 111#@1.900" 155#@1.880" 135#@1.875"
0.500" 308# 340# 335#
0.600" 348# 377# 375#
0.650" 368# 396# 395#
Bind 0.725" 0.650" 0.720"
Cost $121.13 $213.53 $149.95
The Beehive springs would be nice, but the description says they are 0.590" max lift, and if I run a 1.7:1 rocker arm, my lift will be 0.617"
I was also looking at the Hughes HER3642BL cam which is the same 0.050" duration as the comp cam with a bit less lift, and narrower LSA, but costs $87 more than the comp cam, and the recommended valve springs are much stiffer, 185# closed, 505#@0.650" lift? That sounds pretty stiff for a hydraulic roller tappet cam?
Re: Anyone use Isky 8005A valve springs? [Re: 451Mopar] #1027149
07/06/11 09:36 AM
07/06/11 09:36 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I have them on a few engines. No reason to be afraid of them
Re: Anyone use Isky 8005A valve springs? [Re: scatpacktom] #1027150
07/06/11 11:32 AM
07/06/11 11:32 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
451, Isky has retainers & locks for the 8005-A springs in 7 & 10 degree styles.
Re: Anyone use Isky 8005A valve springs? [Re: topside] #1027151
07/06/11 03:37 PM
07/06/11 03:37 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Great springs! I've been running them on my 440 for 10 yrs. now! Jeff@ Modern checked the pressures last year,and they still have plenty of life left in them! I run a Comp solid flat tappet and shift at 6500 at the track. On the street...frequent 6000rpm upshifts...solid as ever!
Re: Anyone use Isky 8005A valve springs? [Re: 451Mopar] #1027152
07/06/11 03:40 PM
07/06/11 03:40 PM
Set up correctly the Isky 8005A are a good spring, I shoot for 140 to 175 lbs on the seats and 325 to 375 lbs opened on most flat tappets(solid) and hydraulic or hydraulic roller cams for the street and strip use i've used many of them before switching to Comp Cams products Comp has a lot more choices on custom lobes and camshsafts, better R&D also
Re: Anyone use Isky 8005A valve springs? [Re: 451Mopar] #1027153
07/06/11 03:49 PM
07/06/11 03:49 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yes, no issues. They are pretty stout. Make sure they meet the cam makers recommendation.
Coming soon!!!!
