Anyone running small block PRW balancers
#1026918
07/05/11 10:17 PM
07/05/11 10:17 PM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
Wondering if anyone has successfully used these.
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: Anyone running small block PRW balancers
[Re: Scotts71chall]
#1026920
07/06/11 12:12 PM
07/06/11 12:12 PM
DragDart360
South Jersey, NJ
I got the solid one then another and the're both going back because the don't fit. The collar is to short and hits the timing index before seating on the crank this would allow the lower timing chain sprocket to float in and out .3" resulting in failure at some point. The collar on the first one was over 1/2' to short and the second .3" shorter than stock. I also had to shave my starter snout to clear their flexplate and their roller rockers to clear the most commonly used performance valve spring diameter. NO more PRW for me. To their credit they did send a return shipping tag and offered a refund on the balancers.
[Re: DragDart360]
#1026921
07/06/11 02:43 PM
07/06/11 02:43 PM
BradH
... To their credit they did send a return shipping tag and offered a refund on the balancers.
And you took the refund, right?
[Re: BradH]
#1026922
07/06/11 02:54 PM
07/06/11 02:54 PM
DragDart360
South Jersey, NJ
Yes, Ordering a replacement from Summit right now!
[Re: BradH]
#1026924
07/06/11 03:22 PM
07/06/11 03:22 PM
DragDart360
South Jersey, NJ
Which one slips? Summit brand, Trick flow?
[Re: DragDart360]
#1026927
07/06/11 07:21 PM
07/06/11 07:21 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
The PowerBond Unit also sold under Pioneer brand & PBM is the only damper I use other than ATI. It's my "budget" choice... have never had a single problem with one, even in 700-750 HP motors, including circle track use. I've probably used 35-40 of them. I've had several Summit SFI dampers fail (slip). http://www.summitracing.com/parts/PIO-872037/
[Re: RyanJ]
#1026928
07/06/11 07:38 PM
07/06/11 07:38 PM
Triple Threat
Renton Washington
I bought an ATI, if you know anyone with a Summit or Jegs pro shop discount they can be had for about $350.
